Sponsored by: Innova
Need tips and ideas keeping subwoofer box from moving.
Old Jun 14, 2013 | 03:37 PM
Rogue-CLK's Avatar
2016 C300 4Matic
Lightbulb Need tips and ideas keeping subwoofer box from moving.
^ without drilling holes and using brackets. Stupid question but what have u guys done to it from moving around. Problem is it moves from the back of the seat to the opening/door of the trunk.
Old Jun 23, 2013 | 04:55 PM
bernard farquar's Avatar
2011 E350, 1998 ML320
I actually used a ratcheting strap, around the box horizontally, then tied it to another going vertically around the box and looped it through some already existing ports in the rear deck, basically hanging the box from the rear deck, but leaving it on the floor of the truck. This solved my problem, it still moves a little, but it no longer pulls the ground wire out of the amp (box mounted).
Old Jun 24, 2013 | 06:58 AM
City Rat's Avatar
Veteran: Army
Currently: 2019 E450 AWD, Previous: 2002 CLK55 Cab
Some folks have the box molded to fit one of the spaces on the side of the trunk. Curios is yours a custom box or an amplifield sub from eith Kicker or Sound ordnance.
Old Jun 24, 2013 | 01:47 PM
Rogue-CLK's Avatar
2016 C300 4Matic
I'll try that^
If that questions for me, Mines a custom box pretty big, I wanted a shallow sub and box but doesn't have enough power to shake my car if u will lol. I've tried using rubber disk like washers 1 on each side, work ok but does move a bit but not as much. Wanna try using this fabric u put in your utensil drawer to keep it from moving and ill c how that goes.
Old Jul 11, 2013 | 01:35 PM
Rogue-CLK's Avatar
2016 C300 4Matic
Rubber disk or washers don't work :/ the utensil liner seems to work not exactly sure what's it's called tho but it keeps they tray of utensils from moving, works so far.
Old Jul 11, 2013 | 01:40 PM
silvertxE55's Avatar
In other cars I've owned I took some Velcro strips and used the side that isn't fuzzy. (If that makes sense lol) just stick it to the bottom of the box and it sticks to the carpet pretty good.
Old Jul 11, 2013 | 01:59 PM
Rogue-CLK's Avatar
2016 C300 4Matic
That's a good idea, guess u didn't use the fuzzy side at all, did u use them on all 4 corners or all along the sides?
Old Jul 11, 2013 | 02:19 PM
Right, no fuzzy side at all. Had a roll of it so did a strip the width of the box on each side.
