Sponsored by: Innova
CLK 430 radio upgrade
Old Feb 16, 2004 | 10:07 PM
monagram's Avatar
2007 CLK 550 Cabriolet
Is it possible to change the headunit and still keep the bose system? Also, does anyone make harness adapters? The car is an '03 CLK 430A.
Thanks -
Jim
Old Feb 24, 2004 | 06:19 PM
CLK 2001 Cab's Avatar
2001 CLK430 Cab.
As you can see, few have any answers ref the Bose system. Apparently it is too complex to deal with. I have a 2001 CLK430 without the Bose; just the std. MB radio. I tried to get help also but got very mixed opinions. I finally pulled the trigger and had a new Alpine M/radio layer put in, replacing the radio/tape player. It works great.
Old Feb 24, 2004 | 07:22 PM
cliffybabe's Avatar
CLK Coupe 200 Komp 53 Plate
I belive that hte bose wont work, with another head unit to to connections between the bose amp and the head unit, as for adpters the back of the HU i belive is a standard iso connection, check out my install in my 209 clk
My Install
Neil
Old Feb 24, 2004 | 09:27 PM
SUNILP's Avatar
2015 E250D
You cannot use any other headunits than Mercedes ones for teh bose system since the input on the AMP is fiber optic. You can upgrade to a comand sytem or toss the bose amp for something else.
Old Feb 25, 2004 | 07:08 PM
x15jq's Avatar
all of you are wrong
i have a headunit in my clk 320 with BOSE right now. It is the SAME wiring, u just will be utilizing the factory amp still. If you DONT want to use the amp then u just need to run a set of wires to each speaker to bypass the amp. The only thing fiber optic on my car is the cd changer andi have a bose system in the cabriolet.
Even on cars with bose its possible. I have seen it on a 02 clk and my 99. On my c230 i had a standard radio tho and that was cake as well,
Just use the metra harness and antena adaptor.
Hope it helps
Old Feb 25, 2004 | 07:09 PM
x15jq's Avatar
03 clk 430a = w208 cabrio i believe, and this is the same as 02 and earlier clk coupes thats why its able to work.
Old Feb 26, 2004 | 12:41 AM
scott cairncros's Avatar
92 300E Sportline
On the 03 there is only fibre optic connection to the amplifier and at this time there is no option other then installing a new amplifier. It is possible to run the new deck to the front and rear speakers directly and add an amp just to run the sub.....
Scott@lajollaaudio
Old Feb 26, 2004 | 01:57 PM
monagram's Avatar
It is a w208. Do you happen to have the metra part numbers? Thanks for the replies.
Old Mar 3, 2004 | 02:00 PM
clkal's Avatar
01' CLK55
this is incorrect. You can easily install any aftermarket din sized unit in a w208. There are 2 adaptors you will need to purchase. The wiring harness adaptor and the antenna adaptor. Any stereo shop should have these 2 items in stock. The install takes less than 20 minutes.
Old Mar 3, 2004 | 02:24 PM
monagram's Avatar
And it will work with the bose system?
Old Mar 3, 2004 | 02:36 PM
clkal's Avatar
01' CLK55
yes it will
Old Mar 4, 2004 | 10:07 AM
monagram's Avatar
Thanks for your help, I will look for the harness this weekend. Is it the VW one that everyone talks about?
Old Mar 4, 2004 | 12:31 PM
clkal's Avatar
01' CLK55
no....it's one made specifically for the mercedes. I believe METRA makes it.
Old Mar 4, 2004 | 02:11 PM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
bull-****z...
just go out and buy a VW harness... I went to circuit city & bought both the antenna adapter & VW harness, and it works fine. no problems whatsoever... totalled about $30
Old Mar 4, 2004 | 02:15 PM
clkal's Avatar
01' CLK55
ooops...guess i'm wrong.... sorry dude
Old Mar 4, 2004 | 03:29 PM
monagram's Avatar
Which VW harness is it then?
Old Mar 11, 2004 | 02:09 AM
mmgrad's Avatar
the one i had bought was for like a 1987+ VW Jetta or something...
just ask for all the VW harnesses and look at the harness... the other ones don't look anything like it
Old Mar 11, 2004 | 10:59 PM
SUNILP's Avatar
2015 E250D
How can a aftermarket head unit work with the Bose AMP since the Bose AMP has a fiber optic input. Does the metra adapter convert analog to fiber? Just curious.
Old Mar 12, 2004 | 10:32 AM
Bouncer's Avatar
2001 CLK 320
Because at least on my 2000 CLK 320 the fiber optic has NOTHING to do with audio. The CANbus (fiber) exists so that the various devices can communicate with one another for data purposes. Actual audio to the AMP and speakers is still carried by the standard wiring.
I have a Kenwood Excelon Sirius/CD-MP3/FM Radio in my car and it's the ONLY aftermarket audio mod I did. Shop had it in in about 20 mins and everything works hunky-dory, even dims when the lights come on.
Regards,
-Bouncer-
Old Mar 12, 2004 | 11:30 AM
SUNILP's Avatar
2015 E250D
on my 2003 c320 sedan, I have a comand system on it. THe audio output connector is not even used in the rear of the unit. The sound goes out to the bose amp via d2b fiber optic bus. Maybe it's different in the clk.
Old Mar 12, 2004 | 02:07 PM
michakaveli's Avatar
E300
Where all the wires the same. I remeber I had ordered a harness for my '97 E300 from the Becker Board and it did look like the VW, I checked it out while I was once before working at Circuit and they seemed identical but I think one or two wires wher either missing or out of place..... I'll be doing the same for my dads '99 so I figured I find out the details now as well....
Old Jul 12, 2012 | 07:12 PM
bahallll's Avatar
CLK2001
Anbody figured out what the Metra part number for the headunit harness is? I have a 2001 CLK320 with BOSE and need to connect the headunit (a Pioneer) in place of the MZB stock stereo.
Old Jul 13, 2012 | 11:00 PM
jbondox's Avatar
beater with a heater
http://www.metraonline.com/part/Volk...arness_70-1784
Old Sep 4, 2015 | 12:03 PM
griffinjw's Avatar
MERCEDES CLK 430
1999 CLK 430 MB
I have a problem with changing out my stock unit with an up-to-date radio. I was told my current unit/speakers is supported with a fiber optic wiring set-up. I was told I need an adapter with two inputs for right and left. Does an adapter exist that's FIBER OPTIC over ANALOG that will support my current speaker system?
R/
Hope it helps
Old Sep 4, 2015 | 12:07 PM
griffinjw's Avatar
MERCEDES CLK 430
I have the same problem with changing out my stock unit with an up-to-date radio. I was told my current unit/speakers is supported with a fiber optic wiring set-up. I was told I need an adapter with two inputs for right and left. Does an adapter exist that's FIBER OPTIC over ANALOG that will support my current speaker system?
R/
Griffinjw
Thanks -
Jim
