Sponsored by: Innova
Can only use MB V60? Wrong !
Old Mar 13, 2004 | 11:41 AM
SUNILP's Avatar
2015 E250D
Yes, all cars have the vrm switch in the steering column. None have it on the actual steering wheel. I have the part no. for the lever if you need. All US cars have wiring for VRM installed already but in different locations than the phone PSE. My VRM is under the trunk carpet and my PSE in the rear right wall of the trunk.
Old Mar 13, 2004 | 11:50 AM
Mik's Avatar
Mik
Wow that is a fact I wasn't aware of. In my car the VRM is right on top of the PSE.
Old Mar 13, 2004 | 12:36 PM
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe; daughter: 2017 GLC SUV
man, you guys are deep....are you saying there's something on my steering column related to the phone that I'm not aware of? All I know about are the radio buttons.
Old Mar 13, 2004 | 02:18 PM
SUNILP's Avatar
2015 E250D
I don't know if your car has this or not but it should. Look at the opposite side of the cruise control lever on the right side of the steering column. There should be a plugged holed there. This is where the lever for the voice control goes. The switch should be inside the steering column already. Since yours is a 2000 model, I would think it's already there. Your car should also have the fiber d2b ring installed so you can also add a phone kit.
Old Mar 13, 2004 | 03:27 PM
eddieo45's Avatar
the car does have the phone kit; I just bought a Timeport on ebay from Carlos Miami---haven't activated it yet, but test calls work great. Would the car have the factory phone kit without the voice control?? ps...how about some pics of your car?
Old Mar 13, 2004 | 06:24 PM
SUNILP's Avatar
2015 E250D
you can see pics of my car at MY SITE If you car has d2b fiber (which I think it does) then you should be able to use the MIKBOX or any other current mercedes phone kit out there. Check the PSE to see if there is a orange colored fiber optic connector.
Old Mar 13, 2004 | 09:36 PM
  #32
breastroker's Avatar
2003 C230 K , 2001 ML320
What if our car did not come with teleaid or doesn't have a PSE?
Anyone have the part for the C class lever on the steering wheel for voice activation?
Old Mar 13, 2004 | 10:06 PM
  #33
SUNILP's Avatar
2015 E250D
I have the part no. for the steering wheel lever for the Voice Recog. I'll post it later on. Teleaid does not have anything to do with what Mik is trying to accomplish. It's a totally seperate system. IF your car has no PSE (phone system electronics) then this will not work. You have get a PSE first. Mik is trying to work on a deal with the older PSE's for the benz since new ones are around 1100 bucks. Nokia PSE are much cheaper that steve can get us but it has not been tested with the MIKBOX. THe UHI has not been tested either.
Old Mar 13, 2004 | 10:12 PM
  #34
SUNILP's Avatar
2015 E250D
Part number for voice control lever
The voice control lever part number is
203-545-0044
000-545-0644
Color code is 9c45.
My EPC shows 2 part numbers. I believe they changed the shape of the lever around 2003. They should both work though. These part numbers are for C classes 2001 and up.
Old Mar 14, 2004 | 12:17 AM
  #35
I could try to get a PSE from a wrecking yard. Where would it be located in the W203 sedans? It is easier to find in wrecked C320's. Where would I put it in my Coupe?
Thanks for the part numbers.
I want a functioning car phone, I hate the bozo'z who swerve all over the freeway holding cell phones next to their ears. I have a good ear piece, but want the MB to have a permanent cell in it.
Old Mar 14, 2004 | 12:38 AM
  #36
SUNILP's Avatar
2015 E250D
It's located in teh rear right side of the trunk on the w203 cars. I believe the same on the coupe as well. You can check my car out here MY SITE The Motorola PSE will be larger than the one in my car. The one in my car is the Nokia PSE.
Old Mar 14, 2004 | 01:05 AM
  #37
Mik's Avatar
Mik
as far as I know, the 2000 C class (W202) was originally equipped with the StarTac. I am not sure if that was prepared for voice recognition, since its not listed in the part number list for that model. However for the W203 it is (PTT Level for W202: Q682-0651), you'll also need the SBS (Q682-0650), or just buy the whole kit including the installation materials.
Old Mar 14, 2004 | 01:11 AM
  #38
Mik's Avatar
Mik
Here is the whole deal from mbusaphones.com
Vehicle Type W203
MBUSA Part Number
Kit Description Q6820712
VEHICLE COMPLETER KIT Q6820577
OPTIONAL VR KIT
Components MBUSA P/N MBUSA P/N
VR MODULE -- Q6820650
CABLE PSE/COMPSTR Q6820468 --
BRKT, VR MODULE -- Q6820654
BRKT PSE/COMPEN/ANTSW Q6820653 --
PTT LEVER -- Q6820651
ANTENNA SWITCH (DUAL BAND) Q6820652 --
TEMPLATE, V60 HOLDER INSTALL Q6820762 --
TEMPLATE, TIMEPORT HOLDER INSTALL Q6820763 --
MANUAL, VR -- S-2765-000
Old Mar 18, 2004 | 11:52 AM
  #39
davidasman's Avatar
2002 C230 Kompressor
cradles...
not sure if this is at all a help but i have the v300 in my car using the motorola full handsfree kit. all the (newer) motorolas use the same basic kit, with different cradles (referred to as hang-up cups). i previously had the v70 and when i got the new phone i simply traded out the cups.
anyways - the cup itself has the motorola 2-part plug and antenna piece that plugs into the back of the phone (covered with a little piece of rubber). the antenna has a mini-UHF connector that fits with the factory antenna wiring.
the motorola connector does not have a cable attached. the cup comes with a cable that goes from there to the brains box... so based on the pictures that you've posted it seems as your piece will clip right into the cup.
i'm not too familiar with the PSE and where the antenna connection goes, but currently i am using the factory antenna without a problem so it should all piece together.
you can check out the v300 cup here...
Old Mar 18, 2004 | 09:36 PM
  #40
Mik's Avatar
Mik
cool. I wonder if the V600 fits in there. That would be a real cheap alternative to the new UHI adaptor.
I wonder though if the newer motorola phones do in fact have the same plug. I just got a Nextel 730 phone today, and although the plug really looks the same, it does not fit.
Old Mar 19, 2004 | 01:41 AM
  #41
Mik's Avatar
Mik
It does fit ! This solves many problems. You can get those for $30 at some places, just crimp on the RJ48, and there, you save over $200 for the cradle.
I ordered three of those hang-up cups, that covers most of the recent popular Motorola phones. Including the 730 which apparently does have the same connector.
Old Mar 19, 2004 | 08:55 AM
  #42
weinschela's Avatar
'14 E350 wagon; BMW G12 (2020) G01 (2019)
There's a full install for the v600. I have it. It works fine. But of course, I've got no interface with Comand or steering wheel -- just terrific handsfree. I expect that when Mik gets his box done, the Motorola braket will work just fine -- only you could then mount it in the center console like a factory phone.
Old Mar 19, 2004 | 09:57 AM
  #43
Steverock's Avatar
Such an interface would be terrific.
Old Mar 21, 2004 | 08:45 PM
  #44
AMIL's Avatar
CLK55
if they can get a braket for my i730 nextel that would be awesome
Old Mar 21, 2004 | 09:28 PM
  #45
SUNILP's Avatar
2015 E250D
Mik is still devoloping the Nextel interface but the regular 730 would be no problem as motorola makes a cradle for these phones at the moment.
  #46
SUNILP's Avatar
2015 E250D
Old Mar 21, 2004 | 09:29 PM
  #47
AMIL's Avatar
CLK55
where cna i get this cradle from?
Old Mar 21, 2004 | 09:47 PM
  #48
Mik's Avatar
Mik
Here is one for the i730
http://shop.store.yahoo.com/original.../nntn4751.html
I'll order one and check it out. The other one I got is for the T730. The i730 is the one that has a different connector.
Old Mar 22, 2004 | 12:36 AM
  #49
AMIL's Avatar
CLK55
alright so if i buy this NNTN4751 can u give me some direction as to how to install it? is it plug and play or do i have to have someone do it?
Old Mar 30, 2004 | 01:14 AM
  #50
amarzano's Avatar
2001 CLK55
MIK,
Any updates? I should have a new V600 in my hands tomorrow and would love to integrate it.. :-)
Thanks,
Alex
