Sponsored by: Innova
W220 DIN or Doulble DIN Installations?
Old Mar 29, 2004 | 01:30 AM
pbxsc4n's Avatar
S430 2000
Has anybody tried to take out the nabigation system and install a single DIN or even a double DIN aftermarket deck to the Bose system, let me know I would like to accomplish this very much... I am not sure how the Nav. system will sound in my 2000 S430 but I hated the deck in my 99 CLK 430 and put a Kenwood in... I would like to totally rebuild the system but need to find out if I can change that Navi. out with an after market deck, any help and or ideas would be greatly appreciated...
pbxsc4n
Old Jun 9, 2011 | 01:23 PM
shottakings's Avatar
s430
can be done..
Old Jun 12, 2011 | 02:52 AM
scott cairncros's Avatar
92 300E Sportline
I have done it... Just needs at least 1 amp to run the sub... Or a 5 ch amp to run the front rears and sub...
Scott La Jolla Audio
Attached Thumbnails W220 DIN or Doulble DIN Installations?-s-220-pioneer-920-bt.jpg
Old Jun 12, 2011 | 11:26 AM
s430
double din installation problems
i put a double din in my 2002 s430 too, but i am having 3 problems.
1. i have to turn the key all the way,about 1 click from starting the car to get and keep the audio to work.
2. I have to turn the double din radio off manually
3. Everytime i turn up the radio too loud, the audio cuts off and i have to turn the car off and turn it back on to get back the audio..
i have a sony 4/3 channel amp and the rest is all rewired because i couldn't find a wiring harness. Any suggestions because i
Old Jun 12, 2011 | 05:31 PM
92 300E Sportline
First the stock radio has no acc power as it gets its signal from the can bus..
So you will have to use the cig lighter for acc power for the new radio and this should turn it on/off properly. The next problem is usuall caused by a low impeadence load on the amp...Probably caused by the sub which is dual voice coil 1 ohm and you have to rewire it in series to get a 2 ohm load and then you have to make sure your amp will handle a 2 ohm mono load... Depending on how you have the front and rear speakers wired that can also be an issue... It might be best to disconnect 2 of the 4 channels at a time to see which ones are causing the amp to shut down...
Old Jun 12, 2011 | 07:44 PM
s430
Thank you...did u have any problems with ur radio stations coming in and out(bad reception)? It is a 600 watt sony amp,so it should be enough to handle a 2 ohm mono load. I will work on it tomorrow and let u know the results..
Old Jun 12, 2011 | 08:14 PM
s430
how do i upload images,,so i can upload my double din pics?
Old Jun 12, 2011 | 08:21 PM
s430
Did ur steering wheel control work..having a hard time finding the rewire connection(puzzled)?
Old Jun 13, 2011 | 12:03 AM
92 300E Sportline
the amount of power you amp has has nothing to do with it... Ck your specs on the amp as you will either have to add another amp for the sub or replace the sub with a 4 ohm..to get your reception to work Pin 5 on the bottom connector should be a blue wire you need to hook this to your power antenna or amp trigger wire and this will power the antenna amplifier.
Scott La Jolla AUDIO
Old Jun 14, 2011 | 04:47 PM
jbondox's Avatar
beater with a heater
I think I have the wood grain DDIN kit in my basement for that, if not ******* will have them.
Old Jun 15, 2011 | 06:35 PM
s430
2002 s430 double din
Thank u very much scott.. hooked up the double din to cigartte lighter and all is good now..had to change the sub and the amp is not cutting off anymore..
Still trying to get a better radio reception.. can u please explain what blue wire(the one that powers up the antenna) ur talking about(kinda confused on that one). Is it at the end of the wires beside the speaker wires that is connected to the amp?
Also, did u get your steering wheel control to work..still trying to figure out what wires to connect for that..
Old Jun 15, 2011 | 08:47 PM
92 300E Sportline
the wire is in pin location # 5 in the stock radio power harness... It is usually blue.... I haven't had any luck getting the pac or metra sw interfaces to work on a w220 so I have installed an older (no longer avail) soundgate sw interface that works most of the time....
Old Jun 15, 2011 | 09:08 PM
92 300E Sportline
this is a diagram for the stock command 2.5
http://www.google.com/imgres?imgurl=...BC1E60143373D6
Old Jun 22, 2011 | 10:36 PM
s430
sorry, can't open the diagram..
Old Jun 23, 2011 | 12:43 AM
92 300E Sportline
Sorry , here is the diagram...
Scott
Attached Thumbnails W220 DIN or Doulble DIN Installations?-mercedes-s-220-comm-2.5-diagram.gif
Old Aug 6, 2011 | 03:37 PM
julianobello's Avatar
2002 S500
This Good Radio Info thx
Old Aug 6, 2011 | 05:54 PM
2002 S500
Where can I purchase the harness from?
Old Aug 19, 2011 | 12:49 PM
BadBenzo's Avatar
00 s430
I GOT IT..
I have the harnes Call me 404 944 7852 I have a whole car for parts 00 s430..
Old Aug 25, 2011 | 11:29 AM
everman's Avatar
00 S430
Do you have the audio Amp for the S430. My stereo keeps cutting out and I believe it to be the amplifier.
Old Aug 25, 2011 | 02:59 PM
BadBenzo's Avatar
00 s430
yeas i have it
