replacing mercedes stock unit in a w203 bose system
mercedes c sportcoupe
hello!
i have a mercedes cdi220 sportcoupe, and i live in europa.
i have the stock MB audio 10 with cd changer and bose sound system. now, i have a friend with a DAB blaupunkt radio. is it possible to replace my stock radio WITHOUT having to change my bose speakers, and wiring ?
thnx in advance
thnx in advance
1 Post
01' CLK55
Re: replacing mercedes stock unit in a w203 bose system
Originally posted by wimpytron
hello!
thnx in advance
hello!
thnx in advance
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Re: Re: replacing mercedes stock unit in a w203 bose system
Originally posted by clkal
you should be able to install an aftermarket deck with a installation kit (made out of black abs plastic), a wiring harness, and an antenna adaptor. You will be able to keep your bose system.
-s-
2015 E250D
you will have to run wires to the rear right of the trunk where all the speaker wires are present attached to teh bose AMP. The head unit is connected to teh bose amp via Fiber Optics only and no analog signals go there. The bose amp to speakers is normal wires
04 CLK500 & 10 GLK350 (Past: 83 380SL, 03 C230 Coupe, 2013 C250 Sedan, 97 C280)
Hello,
I know it has been a while since anyone has responded to this page, but I'm in the dark so here goes...
I have recently gotten my hands on an original MB Bose amplifier that's come off a W203 coupe, and an original MB Bose subwoofer that's also come of a W203 coupe.
My completely stock 2003 C230 K Coupe has the non-Bose factory sound, no navigation, with 6-disc CD changer, and for what it's worth, the bluetooth prewiring in the armrest.
Anyone know if my car prewired for the Bose Amplifier and Bose Subwoofer?
Thank you,
Ryan
Thank you,
Ryan
a lot of rewiring for a subpar system... if only 15 years ago I knew that all the pieces I was upgrading and tossing in the trash would be worth something today... i'd have more retirement money. I guess what I am trying to say in a nice way is why bother with some antique outdated equipment that was subpar to begin with? a nice alpine pdx9 or audison sr5 amp and some speakers with a sub would be a huge improvement.
no harness. add the sub, then add an aftermarket amp. I wouldnt give up just because it isnt OEM, there is so many good aftermarket companies and shops out there that can have it sounding so much better
Also, should I wait to install the sub when I have an amp ready to be installed? As in, if I install the sub and not install an amp, will that be damaging to my system?
Thank you!!
