Sponsored by: Innova
adding DVD HELP
Old May 19, 2004 | 11:16 PM
r207's Avatar
w203
adding DVD HELP
OK this is what i have
Euro comand
tv tuner,
I want to hook up an external DVD player to the tv tuner and watch movies. however i am unsure where i should run the power from or to....
can i use the fuse block in the back and run one from a spare.....if so where can i buy one of those little plastic things from
HELP i wanna get this in the car soon
Old May 24, 2004 | 12:27 AM
r207's Avatar
w203
ok, so not one person here has had to hook up a dvd player in the car....
all i need to know is where can i run the poer from so that the unit will switch on and off when the command is on/off
steve are you out there
Old May 26, 2004 | 07:55 PM
davidasman's Avatar
2002 C230 Kompressor
any ignition-switched fuse will allow the dvd player to turn on when the car is on and will turn off with the car off. i'm confused as to what exactly want - do you want the DVD player to know when your COMAND is on and turn on? the COMAND is connected to an always-on fuse. in your car the fuse for that circuit is under the hood. it's possible to have the DVD player come on only when the COMAND is on...but i can't see any reason why you'd care? anyways - there are various switched fuses you can use - search the forum. and as for any "little plastic things" you're talking about - radioshack should do the trick.
Old May 26, 2004 | 09:12 PM
r207's Avatar
w203
thanks for the reply,
im just lookng for the best power supply for the DVD player, and ill either use the fuse block in trunk, or the lighter socket.
all i want it to do is have it turn off when the car is off....
Old May 26, 2004 | 11:36 PM
davidasman's Avatar
where are you putting the DVD player? if you're putting it in the trunk than there's NO reason to run power from the cigarette lighter when there's a fusebox right there... if you're putting the DVD player say in the glovebox than using the cigarette lighter would make more sense...
Old May 26, 2004 | 11:51 PM
r207's Avatar
w203
yeah im gonna use the glovebox so the lighter is the best option...
whats the best spot for constant power or do i just run it to the battery?
Old May 27, 2004 | 11:57 AM
davidasman's Avatar
from the glove box either the battery or the radio/COMAND
Old Jun 2, 2004 | 01:08 AM
r207's Avatar
w203
at the back of the command which wire do i tap into for constant power, or can i just use any of them
