Dension Ice>Link Plus (Mercedes Ipod Integration) Install and Review
As for the A/B switch this will be a work in progress. I first need to find out if any such product exists. I have a basic idea on how to make one, but not on how to integrate it into a one flip of a switch solution as of yet.
BTW, Tom at Dension used to work for EvoSport and as such is very familiar with this forum.
the cable to the ipod is the biggest issue (unless the iPod is in the trunk). Is
there anything to be done with the head unit in terms of pulling it out? My IceLink is suppose to be here on March 2nd. Thanks.
See this link for info:
http://www.densionusa.com/images/ins...tall_guide.pdf
Excellent! I just downloaded the install manual and from your excellent write-up,
it should be a snap.
My iceLink >Plus should be here today. So, my only question is.... Where can
I get a mating power connector to fit the built-in OEM power connector. I too
like to keep stock as much as possible without cutting anything up. It sounds
like I need a mating power adapter to fit the OEM power connector.. Correct?
I assume there is only two wires in the three connector that's in-use. Thanks.
the right part# for the male 3-pin connector should be A 030 545 59 28 (housing) and the pins (you need three of them) A 032 545 39 28.
like most of you have used. Nice to keep OEM plugs intack. I should have the
connects next week..... I'm thinking of docking the iPod in the trunk. What have
most of you done? I see some in the console. Anyone else mount theirs in the
trunk?
I use playlists extensively, and after selecting one I rarely have to refer to the screen. Adam Winer's installation of the iPod using a cable makes his screen easy to read, and maintains steering wheel control, silencing for incoming phone calls, and other elements of integration that an AUX input in a D2B equipped car may not give you.
Since relocating the iPod, my installation is usable, though having ID 3 Tag info on the car's displays would be more useful. Though lacking Tag info, I have what I need - and I like the rest of the integration.
Also, this version fixes a sync problem that I had experienced a couple of times.
The update went smooth and as per instructions. No need to circumvent things to get it updated this time as was the case for version 2.05 !
Also, this version fixes a sync problem that I had expiranced a couple of times.
Posts in this string starting at #70 and running through #104 deal with this somewhat; the specifics of what you see depends on whether you are in the Dension UI or the iPod UI, and where you are in the UI. The car's displays show only "CD #" and "Track #" - and they mean different things at different times.
The following addresses what you see in the COMAND and instrument cluster displays. What you see in the iPod screen itself is discussed extensively in the user manual on the Dension USA website ( http://www.densionusa.com/images/ins...ers_manual.pdf ).
One example of how it works:
On the car's displays, in either UI, if you have organized your music into playlists, your first five playlists will be shown as CDs 1-5; and the track number of the selected song within the playlist is displayed. CD (Disc) 6 places you into the Dension UI, or if already in it, takes you back to the Dension UI starting point (on the iPod screen only - that is, it takes me to my iPod's name, below which is the list of playlists). However, if you choose a playlist greater than #5, the "CD" corresponding to the playlist number becomes inaccurate. For those, either CD 1, 2, or 3 is displayed, and serves only to show you that you have changed playlists. If you wish to confirm that you are in a particular playlist above #5, you must refer to the iPod screen.
Once you have entered a playlist, "Track" refers to the order of the song in the the sequence it appears within the playlist. Track numbers referring to songs go from 1-99; if you have more than 99 songs, the 100th song starts with #1 again. If you were in the iPod UI and displaying all songs, the same thing would happen; "Track 99" could mean song 99, 198, 297, etc.
The information displayed on the COMAND or instrument cluster display is CD number and track number - no names. I have been able to name my first three playlists in COMAND memory, but 4 & 5 always have the same name.
If, instead of using playlists you use other means of accessing your music, you will still get only "CD" number" and "Track Number" in similar fashion - I'm not going to list all of the combinations, because I don't use them and haven't mapped it all out. Just trying it out showed me quickly that it wouldn't be useful.
As you can see, it isn't ideal. However, because I organize my music into playlists, and because I can refer to my iPod screen for confirmation when necessary, I get by OK - but would certainly like to have the ID Tag info on the car displays.
Burning DVDs is a viable alternative. It takes about 9 DVDs to store as much music as I do on my 40 GB iPod, and one couldn't carry them as conveniently as I do the iPod for listening while on a commuter train. But the best solution for you will depend on how you use and listen to your music; and for many of us, also whether our cars have DVD playback capability (mine does not).
Of course, I have full access to whatever is on my iPod, with all of the sort options provided by the iPod (in either UI), by referring to the iPod screen; as you mentioned, that is something you don't have with DVDs.
Those are just some more detailed reasons not to put the iPod where you can't see its screen, as addressed above for trbo2nr - a mistake I made in my initial installation (thinking I would have ID Tag info available via COMAND).
As I understand from other posts, even the new OE Mercedes iPod integration for some '05s and for '06s provides ID Tag info on the instrument cluster display, but not the COMAND display - but I haven't seen it myself.
-s-
-s-
-s-
Yeah, off- topic. But I agree that the ease of updating the iPod is another advantage.
the head unit. The iPod shows Dension etc. and the playlist I created but not
the head unit. I thought the head unit should at least show the playlist so one
would know where they are in their music lists. Did I forget to do something in
the install or does the Dension unit need to be updated? If so, how. I'm looking at the documentation again and visiting their website. Thanks guys.
break in.........
That's why my changer is on ebay
The iPod integration is the way to go.
Scorchie has posted information on the integration that Mercedes announced for some '05 and '06 models. Search "Scorchie" and "iPod."
I have written up my installation in my '00 S500 at http://www.benzworld.org/publications/pub.asp?id=330 and have included links to other helpful sites, including Dension's.
Happy browsing.
