[Stance Lab] C350 coupe Build
Old Jul 4, 2012 | 09:37 PM
  #76
andrew e coupe's Avatar
2017 E400 Coupe & 2018 GLC43
Originally Posted by ricecooker713
We are using these wheels only for street/rolling.
These are stock S63 wheels with +43 offset.
the best offset i can find in these wheels is a 45mm front and rear... almost makes me want to by a set in 19" in a replica wheel and have the professionally machined down to a 50mm... thoughts?
i really like the end result of these wheels on a c coupe... retaining the oem clean look but with a subtle upgrade.
Old Jul 5, 2012 | 10:19 AM
  #77
Blinks's Avatar
Mercedes Benz C250 CDI coupe
I dont get what you mean by machined dow to 50mm? Do you want a more aggressive set up, then your going backwards then. Sorry im confused.
I do have to admit the S63 rims do suit the car very much.
Are there pics of the car with them rims at ride height???
Old Jul 5, 2012 | 04:24 PM
  #78
itsLoonie's Avatar
2012 E350 RWD
He means machine down the back of the wheel hub which increases the offset UP. He doesn't want to go more aggressive than it already it is for him.
Unlike most of the people on the forum, I am a fan of slammed cars. I think this looks nice. Even though I am still not a fan of the face lifted C-Class or coupe.
Getting mine set up installed by StanceLab as well except I have a pre-face lifted sedan. Can't wait for it to come in!
Old Jul 5, 2012 | 10:21 PM
  #79
Thumbs up
~ yep... thanks for the advanced reply.
if you look closely at the pic below the rims edge is extended past the tires side wall ...
(the rim is hanging off/outside the tires edge)... this is because the offset is incorrect.
a 50mm offset on the rear rim keeps the rim inside/aligned with the wheel well and can have the tire fit correctly with the appropriate sidewall.
Old Jul 6, 2012 | 12:36 AM
  #80
ricecooker713's Avatar
C63 E63
The offset is pretty proper for this car. The only/main reason I stretched the rear tires is to achieve this look. If I didn't want to slam my car, it would be unnecessary to stretch the tires. The wheel and tire will never reach that high into the wheel well.
If you run +50 offset on a 9.5 wheel in the rear, you will have good fitment but can also run +45 and not have an issue as well
Old Jul 6, 2012 | 12:38 AM
  #81
C63 E63
I just heard about this the other day. Can't wait to check out your car. Are you keeping the same wheels?
Old Jul 6, 2012 | 12:39 AM
  #82
C63 E63
Originally Posted by VIPCHOI
damn, love your car, my inspiration, does the rear diffuser fit the c250 coupe?
Thank you. Yes, the diffuser fits a C250 coupe and sedan. You will just have an empty exhaust hole on the passenger side
Old Jul 6, 2012 | 12:40 AM
  #83
C63 E63
Originally Posted by olszowa12
Sick build What wheel brand are you going for?
Something special... just got to wait until SEMA
Old Jul 6, 2012 | 01:31 AM
  #84
itsLoonie's Avatar
2012 E350 RWD
Yes, I will be keeping the wheels for now. Rears are a little more aggressive than most members here except for the front.
F: 18x9 +40 (5MM spacers) 215/40
R: 18x10 +32 (Reverse mounted with 3MM spacers) 225/40
Old Jul 6, 2012 | 01:33 AM
  #85
C63 E63
Wow, got a picture of the rear fitment?
Old Jul 6, 2012 | 02:02 AM
  #86
itsLoonie's Avatar
2012 E350 RWD
Some pictures from about 2-3 months ago. I may have went a little too aggressive though. Ran into a mishap when my brother borrowed my car and ran into a big pothole. Rear driver side fender lip got mangled a little.
Sorry for hijacking the thread. I know this is about the coupe and all
Old Jul 6, 2012 | 11:15 AM
  #87
C63 E63
Wow, nice set up. Its going to sit pretty flush when all done. No worries, not hi jacking the thread. Awesome gold hardware
Old Jul 6, 2012 | 12:10 PM
  #88
Blinks's Avatar
There is no correct or incorrect offset, its what you are willing to make fit ahhaha thats how i see it! If you want to play it safe go with a +50 or even a +55 and youll be fine.
Im just so accustome to people going the other way.. machining down to get a more aggressive set up not the other way around. Each to their own I guess, but why dont you just start off with a wheel that has a +55 offset already, plenty out there rather then going to the trouble of machining down???
I think its pretty evident that his going for a stretched tyre look, not so much "incorrect" offset lol
Old Jul 6, 2012 | 12:14 PM
  #89
Blinks's Avatar
Thats what im talkin about! Nice aggressive set up! Exactly what im looking for! How much work did you have to get done to get them to fit and how is the ride quality?? Feel free to PM.
From what i can see, you've stetched the tyres, dialed in the camber and i assumed you rolled and lipped the fenders. Anything else?
Old Jul 8, 2012 | 05:48 PM
  #90
C63 E63
One awesome thing about the Airrex wireless air management is the remote. It is charged through a USB cable and comes with an A/C to USB adapter, but luckily for us, we have an USB port in our center console. Nice compartment to safety hide and charge the remote
Lowered
Normal driving height without rubbing
Old Jul 8, 2012 | 10:34 PM
  #91
Blinks's Avatar
Lowered
[Stance Lab] C350 coupe Build-img_1009.jpg[/quote]
Nice height.. No rubbing at all? even on full lock?
Where did you get the wheels from and are they 8.5 front and 9.5 rears with ET43?
Old Jul 8, 2012 | 11:13 PM
  #92
C63 E63
No rubbing at all, fast turns, u-turns, nothing. These are stock S63 wheels
Old Jul 8, 2012 | 11:47 PM
  #93
Blinks's Avatar
Do you mind me asking where you go the S63 rims from and price? Feel free to PM if you wish.
Old Jul 9, 2012 | 03:17 PM
  #94
itsLoonie's Avatar
2012 E350 RWD
Looks good with 20s. Wonder how low mine will be with 18s
Initially I was going to get the whole AirRex package (suspension and management) but after seeing Accuair, I knew that was the system I was going to run.
Old Jul 20, 2012 | 01:28 PM
  #95
VIPCHOI's Avatar
2012 C250 Coupe 040 black
i look at this thread once a day...inspiration
big ballin $$$, i want bagggggss
Old Jul 20, 2012 | 02:06 PM
  #96
Cleanbenz's Avatar
2010 E350
Just decided I'm going the Airrex bag/strut with Accuair V2 management. The pics above just sold me on it! Looks fantastic!
Old Jul 20, 2012 | 04:05 PM
  #97
itsLoonie's Avatar
2012 E350 RWD
Welcome to the club
Have my AirRex and Accuair e-level setup sitting in the boxes still. Appointment isn't until next month. Sure we will both love our setups
Old Jul 20, 2012 | 04:41 PM
  #98
wnunez89's Avatar
c350coupe, Gencoupe R-spec
god i wanna bag my new coupe so bad now!!! -_-
Old Jul 20, 2012 | 04:47 PM
  #99
Cleanbenz's Avatar
2010 E350
Welcome to the club
I probably won't get mine until this winter when I park the car, gonna need to save up a bit.
Old Jul 20, 2012 | 11:57 PM
  #100
itsLoonie's Avatar
2012 E350 RWD
Ah I see. Yea it does hurt the bank a bit. All good though, I will love the outcome. Will post pics when I get them on.
