C250 Coupe Tune available from Burger-Motorsports?
If I wanted real power, I can drive my GT-R. This car was supposed to be a calm commuter that I wouldn't have to worry about and that I could take where I couldn't take my other cars (e.g. when I have to valet park it).
The power loss is not like a Prius, it's worse.
That being said, I'm not too impressed by it or happy with it.
I'm going to sell it:
https://mbworld.org/forums/c-class-c...s-jb-c250.html
You have to at least give it a try.
also I wonder if the unit can handle the heat. I love in Las Vegas and its the dead of summer now. I am going to order the air intake now and stay tuned for more updates on the product. I LOVE it.
Side note: I leased a C250 in april and 3 months to the day a kid lost control of his new Camaro and crashed into me on the freeway, totaling my Benz out. I just leased another one . Arctic white with black interior. LOVE IT. keep the mods coming.
Then I reconnected the battery. So it was disconnected for at least 20 minutes. Started the car and no settings had been lost that I could see.
I imagine I am not as aggressive a driver as many in this forum. I bought the car for quiet, comfort, looks and gas mileage, not for speed. I love the car but hated the turbo lag. I found it to be on the edge of dangerous.
I did not touch the stock settings on the tune. I am very happy with the my initial driving experience although it has only been a couple days. As I believe I read earlier in this thread it feels like I am driving in S mode now while I am in E mode. The lag is much less pronounced and that was the main reason I purchased this. No it is not perfect but I am much happier with the way it drives now vs before. I would say 75-80% better.
I have not had a chance to get into it hard, such as when passing but it does accelerate smoothly when I step on it. I cannot tell any real difference in that regard but I have no complaints at this point.
I will report back to the forum in a couple weeks with more impressions and gas mileage results as I am really curious how that will look.
Thanks for all the other posts. Information is king.
however... lately under heavier acceleration... i am noticing cut out (and i have never opened the box to adjust the settings). this is bothersome to me. perhaps i will place a call to the supplier for suggestions.
QUOTE]
Did you two already try disconnecting the battery for 10 minutes to see if it fixes the "turbo cut out" aka limp mode issue? I would like to get confirmation that this actually fixes the issue. Worked for me...
For instance, in some of my videos of my aftermarket quad exhaust. When shifting you can hear a release of air out of the back exhaust tips. It is similar to a C63 sound when shifting, but not nearly as aggressive. I would previously have this sound even when moderately accelerating. But now I only get this on WOT shifts. Additionally, my car pulls MUCH better, especially under WOT. I am going to do a new 0-60 run and post it to YouTube, I expect much better results.
I'm guessing that any power adjustment to jbtune may warrant a battery disconnect to reset ecu because the ecu seems to have issues automatically adjusting to boost and air/fuel changes from the tune. If there is anything I learned from working in the IT industry is to reboot your computer/server everytime you make any big changes. ECU is basically a computer module so rebooting the sucker seems appropriate.
Also, I think my mpg went up too because I've been getting 34-35mpg on my freeway drive to work in light traffic since battery disconnect vs 32-33mpg previously. I've gotten 35.6mpg a few times already.
Lastly, you still can get overboost with this, its not a 100% fix. Its just VERY difficult to get overboost after doing this. Like I said, I was purposely using driving characteristics that would set it off, and it still took a while for me to hit overboost AND I'm at 100% tune power. Additionally, when I did hit overboost, the car didn't feel nearly as much of a "slouch" on the highway in limp mode. I almost wasn't sure that I was in overboost mode. However, when you get down below 45mph ish the car feels like a boat again in overboost mode. Also, when you shift in overboost mode, you get a nice lurch in power, kind of funny.
THANKS!!!
Do the battery disconnect (negative terminal) for 10 minutes. Trust me on this. I experienced the same exact symptoms both of you had:
1) losing boost/limp mode jumping on freeway in the morning (always in the morning, never after work)
2) having to let go of throttle when the car is "lurching" or else it will go to limp mode
Battery disconnect made the car much more smooth. I don't get that lurch and shifts feel smoother.
It's easy to get to battery: remove that plastic air circulation box on the upper left corner of engine bay by unclipping the 3 clips then then battery is right there.
You will thank me later.
thx alot
The only thing was that the clock in my car was off by 10-15 minutes (as long as the battery was disconnected for), but it quickly readjusted I'm assuming from the navigation system.
Did you two already try disconnecting the battery for 10 minutes to see if it fixes the "turbo cut out" aka limp mode issue? I would like to get confirmation that this actually fixes the issue. Worked for me...[/QUOTE]
I never did disconnect the battery but I had the same problem. I noticed it seemed to happen when the car just started up for a few minutes . I just installed the cold air intake and took it for a test drive again. Now I get it. The guys at Burger are smart. It's faster and more powerful but the real turn on is that I can run the car in echo mode and it runs like a regula V6 with absolutely no lag and all the power you need in the low end. It corrects all the drivability problems that it comes with stock, running in echo mode. It also corrects the whip lash it gives you once the boost kicks in when running it stock with echo or sport. It's smooths the whole experience out.
