HID Kit C250 coupe
Old Nov 13, 2012 | 08:38 PM
Igor1080's Avatar
2013 C204
Question HID Kit C250 coupe
Has anyone installed an HID kit for the non xenon equipped coupes? I'm looking into this right now and I wanna know how much it costs and how hard it is to install?
Old Nov 13, 2012 | 09:43 PM
AV1's Avatar
AV1
C204 C250-CDI
This is a recent thread with the same topic in question - hope it helps
https://mbworld.org/forums/c-class-c...new-owner.html
Old Nov 13, 2012 | 09:49 PM
Igor1080's Avatar
2013 C204
I need more info than there is in that thread. Specifically to answer the above posted questions.
Old Nov 13, 2012 | 10:12 PM
andrew e coupe's Avatar
2017 E400 Coupe & 2018 GLC43
~ the kits are a plug & play diy... and rather easy to install. the harness from the aftermarket kit plugs into the existing factory harness. i have installed a few sets to cars with a projector style headlamp as the C250 offers. be certain to order the correct bulbs for your application.
the hid kits use to be $250 or so but can now be purchased for much less via ebay.
hope this helps.
Old Nov 13, 2012 | 10:29 PM
Igor1080's Avatar
2013 C204
hope this helps.
Any ideas as to what brand I should buy? Some links would help. I wish I could have went for the Lighting package but there were none available from the dealers in my area.
Old Nov 14, 2012 | 12:13 AM
AV1's Avatar
AV1
C204 C250-CDI
As per andrew's post Igor, I too have installed a few of these in other vehicles of mine all of which feature projector type headlamp assemblies as pointed out by andrew above.
If you can wait till the weekend I'll post up pics of a recent one I did showing what's required and the product packaging of the HID kit I used which you can then source from the net or shop - again as pointed out by andrew it is fairly straight forward to do
Old Nov 14, 2012 | 12:14 AM
Igor1080's Avatar
2013 C204
The pics would be appreciated, I'm not in a rush.
Old Nov 14, 2012 | 08:34 AM
the "plug and play" kit is easy to install. total install time... an hour or two. no cutting... no splicing... just plugs into the factory harness.
the kit comes with xenon bulbs, ballast, relay etc...
a set i installed in a prior car... here are the pics of where i mounted the hid hardware (you must have a flat surface). the relays are mounted using existing posts...i added a nut to secure relay. extra wire ties keep things nice and tightie (lots of extra wire). the boxes and hardware seem to be smaller in size now (this kit was in a '04 crossfire i had).
drivers side:
passenger side:
Old Nov 14, 2012 | 08:41 AM
~ here is a set for your application:
http://www.ebay.com/itm/MTEC-XENON-H...f9b772&vxp=mtr
4700k is recommended for the oem look.
~ and another set at better pricing: http://www.ebay.com/itm/H7-XENON-HID...4ea8c4&vxp=mtr
Old Nov 14, 2012 | 11:41 AM
hvc350's Avatar
2012 C350 Coupe
Greetings Igor....
I am in the same boat as you. My 2012 C350 came without the lighting package (bought mine December 2011 when cars with lighting package were scarce).
Does anyone know how difficult it would be to change out halogen headlights for these original OEM xenon headlights? Is it even feasable?
http://www.ebay.com/itm/2012-MERCEDE...7ee76f&vxp=mtr
Old Nov 14, 2012 | 04:05 PM
AV1's Avatar
AV1
C204 C250-CDI
Hi Igor, andrew's covered it well
I'll still put up some pics of mine too on the weekend for further assistance if it helps, I'll note that for a couple of the HID installs I've done (3 different vehicles to date - 2 Opels and one Mazda) the 2 Opels required some 'minor surgery' to the plastic/rubber backing cover of the main headlight beams on the back of the headlight assembly, but from andrew's description above it would seem there's no need as was the cae for my Mazda.
One other aspect to keep in mind is that for headlight main beam assemblies which are not of the projector type, installing HID's may cause some problems with the light beam spread and 'dazzling' to other road users I'm not sure how well or not the standard MB OEM headlight assemblies work with HID's installed, all my vehicles I've done listed above have projector headlight assemblies and work well with HID's.
Old Nov 15, 2012 | 03:21 PM
Rushmode's Avatar
2012 C350 coupe
Please post a tutorial/pics of the install if possible. I'm interested as well.
Old Dec 4, 2012 | 12:08 PM
suka4thong's Avatar
2013 C250 coupe
yes! yes!! please!!
DIY with pictures please
