Roll fenders
Old Feb 9, 2014 | 03:52 PM
amgboyw204's Avatar
c250 coupe .2012 e550 coupe
Roll fenders
Anyone on here know where I can' get my fenders roll in the DVM area
Old Feb 10, 2014 | 10:43 AM
r2racer64zl's Avatar
C350 coupe 2012
wow what set up are you running? what size rims, offset and tires?
Old Feb 10, 2014 | 11:01 AM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
I had a friend who had a high-end shop roll his fenders on his C350- needless to say both rear fenders and quarter panels needed to be replaced. They said the metal Mercedes used was extremely difficult to work with. Why not consider the rear panels from the Black Series conversions?
Old Feb 10, 2014 | 01:14 PM
amgboyw204's Avatar
Originally Posted by r2racer64zl
wow what set up are you running? what size rims, offset and tires? Thanks
. Am runing 19s with a 40 offset 265 30 tires in the rear. The car only rubs on the passenger side
Old Feb 10, 2014 | 01:18 PM
amgboyw204's Avatar
Then I would have get the whole Black series kit to make it look good , I'll just sell the wheels even tho I just bought the H&R super sports spring I guess there no point of me lowering the car when it's already rubbing over bumps
Old Feb 10, 2014 | 11:34 PM
Baker250's Avatar
C250
I used to rub but i cut the inner lining of the rear fender and shaved where the bumber and fender meet a bit and had pulled them a little, also im running -1.9 camber which helped stop the rubbing
Im running 19x10 et 42 with a 255/30. Im lowered on h&r super sports with 5mm pads in the read.
Check out the w204 & offset thread for pics,
Hope this helped
Old Feb 11, 2014 | 08:02 AM
amgboyw204's Avatar
Originally Posted by Baker250
I used to rub but i cut the inner lining of the rear fender and shaved where the bumber and fender meet a bit and had pulled them a little, also im running -1.9 camber which helped stop the rubbing Im running 19x10 et 42 with a 255/30. Im lowered on h&r super sports with 5mm pads in the read. Check out the w204 & offset thread for pics, Hope this helped
. Thank u so man this helps a lot for a minute I was thinking that I need to sell my wheel an get a high offset thanks. I have a set of the h&r SSS I went to a shop In my area to lower the car they said it could not work cause the rear tires are too wide
Old Feb 11, 2014 | 08:46 AM
amgboyw204's Avatar
[QUOTE="amgboyw204;5938093"]. Thank u so man this helps a lot for a minute I was thinking that I need to sell my wheel an get a high offset thanks. I have a set of the h&r SSS I went to a shop In my area to lower the car they said it could not work cause the rear tires are too wide.
Where do I get the camber kit , Is it only for the rear.
Old Feb 11, 2014 | 12:27 PM
Baker250's Avatar
C250
In that case they dont know much about lowering cars haha
I didnt use a camber kit since i didnt put a lot of camber, when i took my car in i just told the tech to put much as possible on the car. -1.9 was all i could get .
If you want a higher offset you could always just take the wheels to get shaved to a higher offset
Old Feb 11, 2014 | 01:11 PM
amgboyw204's Avatar
In that case they dont know much about lowering cars haha I didnt use a camber kit since i didnt put a lot of camber, when i took my car in i just told the tech to put much as possible on the car. -1.9 was all i could get . If you want a higher offset you could always just take the wheels to get shaved to a higher offset
Ok question. If I only use the 5mm pads an the h&r super sport spring" Do u think it will still rub with out the camber kit
Old Feb 11, 2014 | 01:16 PM
amgboyw204's Avatar
[QUOTE="amgboyw204;5938444"] Ok question. If I only use the 5mm pads an roll my fenders with the h&r super sport spring" Do u think it will still rub with out the camber kit[
Old Feb 11, 2014 | 02:10 PM
Baker250's Avatar
C250
You dont need a camber kit to get negative camber, its only needed when you want to get more than -2, which in your case you wont need
Old Feb 11, 2014 | 02:50 PM
amgboyw204's Avatar
Could u send mi a link of wat I need plz. I would really appreciate it
Old Feb 11, 2014 | 03:23 PM
Baker250's Avatar
C250
After you get ur suspension installed and fender work done, go get an aligment just tell them i they could put -2 camber on the back with 0 toe. Thats all thats needed, i dont have a camber kit on mine
Old Feb 11, 2014 | 06:01 PM
amgboyw204's Avatar
. Ok thank you "appreciate it I'll let u know u it works out
Old Feb 11, 2014 | 06:03 PM
amgboyw204's Avatar
[QUOTE="amgboyw204;5938883"]. Ok thank you "appreciate it I'll let u know how it works out
