Side market light options.
Old Feb 2, 2019 | 09:45 AM
mrm143's Avatar
2012 c250 coupe
just looking for opinions.
White 2012 c250
looking to do my first mod and replace the side markers since one of the bulbs is out anyway.
I was was looking at the smoked vs clear vs led vs regular bulb. Also at white or yellow.
What at do you guys think looks the best on the white car?
Im also going to be upgrading the halogens to either HID or LED. I miss having the HID’s like my last car. I don’t have the projector lenses so I know you guys must have preferred venders etc.... any help is greatly appreciated.
Old Feb 2, 2019 | 11:21 AM
AZN Optics's Avatar
SPONSOR/MBworld Guru
White 2012 c250
Clear markers with white LEDs. And HIDs over LEDs for low beams in those housing for better results
Old Feb 2, 2019 | 11:23 AM
mrm143's Avatar
2012 c250 coupe
Are the headlights an actual full assembly or a bulb swap?
any vendors you guys have good luck with?
Old Feb 2, 2019 | 12:10 PM
AZN Optics's Avatar
An HID conversion kit using your existing housing. Fairly easy DIY. Functionally plug and play. We carry top end Morimoto H7 conversion kits if interested. We also have 194 wedew leds for your markers. All of our products are canbus enabled so error free.
Old Feb 2, 2019 | 12:17 PM
mrm143's Avatar
2012 c250 coupe
dont I need projectors in the housing for the HID?
Old Feb 2, 2019 | 01:08 PM
AZN Optics's Avatar
Ideally yes to help focus the beam and we have projector retrofit kits available. However with the c204 reflector design don't really have a huge glare problem. You won't have a crisp cutoff, but not the huge glare issue you see in older reflectors either.
Old Feb 2, 2019 | 01:09 PM
mrm143's Avatar
2012 c250 coupe
it doesn’t have projectors in it at all. Just a regular halogen headlight housing
Old Feb 2, 2019 | 01:10 PM
mrm143's Avatar
2012 c250 coupe
if if you don’t mind just get me the model number of the kit.
How big of a job to retrofit the projectors?
Old Feb 2, 2019 | 02:09 PM
AZN Optics's Avatar
Yeah, never said it had projectors, but you can do a projector retrofit. This is the kit that most go with.
Morimoto Mini Stage3 Projector Retrofit Kit
A retrofit project is more involved and I wouldn't classify as an entry level DIY project. You have to bake open your housing to be able to screw in the projectors. I'd recommend getting a shop to do it for you. An HID conversion though is a DIY project as you're just plugging everything into existing housing/wiring.
Old Feb 2, 2019 | 02:12 PM
mrm143's Avatar
2012 c250 coupe
thanks for all the help. Which kit would I get minus the projector?
Old Feb 2, 2019 | 04:08 PM
AZN Optics's Avatar
For just an HID conversion
Morimoto H7 HID conversion kit
