Fuel/Start up/ Check
Old Apr 29, 2025 | 06:21 AM
V.A's Avatar
V.A
C300
Exclamation Fuel/Start up/ Check
Hello, I am new here.
My 2020 c300 have such problem: after refilling fuel it has problem with start up, about 6-7 seconds and after start check engine comes out, misfire, transmission does not work. These problems occur only when filling the fuel ( car is off). Also, After that there is "Gas Cap Loose" Problem too.
Attaching video:
Please, share any thoughts and experience.
Old Apr 29, 2025 | 06:27 AM
W205C43PFL's Avatar
Attaching video:
https://youtu.be/Ctdtam6SVyM
Did you try changing the fuel cap first? Did you use "Top Tier" certified fuel?
Old Apr 29, 2025 | 09:25 AM
V.A's Avatar
V.A
C300
Yes, I have changed fuel cap and I use "Top Tier" certified fuel. What surprises me is that these problems occur only when I add fuel and start the car.
Old Apr 29, 2025 | 09:35 AM
W205C43PFL's Avatar
Time to scan vehicle for codes.
Old Apr 30, 2025 | 03:35 AM
V.A's Avatar
V.A
C300
P04427A; P218862; P030185
Combustion misfiring of cylinder 4 and 1 has been detected.
A fine leak in the evaporative emission control system was detected .
Old Apr 30, 2025 | 07:58 AM
W205C43PFL's Avatar
Misfire.... And leak hmmm is it part of the fuel hose recall? Forgot the details but there was a recall for something fuel system related on the W205.
Old May 1, 2025 | 05:30 AM
V.A's Avatar
V.A
C300
Thank you all.
I have tested evap purge valve and it was fault. Changed it and everything is OK.
Old May 1, 2025 | 06:58 AM
W205C43PFL's Avatar
Thank you all.
Good job and good to hear
