97 C280 Running Hot !!
Old Jul 23, 2002 | 09:09 PM
bklynz00's Avatar
1997 C280
Exclamation 97 C280 Running Hot !!
Please Help.. My MB 97 C280 is running extremely hot while running the AC, and in heavy NYC traffic. The car seems to cool off when it is moving. The Temp. goes in the red and one day almost beyond. Again, this only happens when the AC is running. Any one with advice ?
Old Jul 23, 2002 | 10:30 PM
David C Klasse's Avatar
1995 C280 & 2002 CLK320 Cabrio
Check the thermostat! I'd replace it regardless, it's cheap. I'd also change the coolant.... and do a 60/40 mixture of water/coolant (MB). Have the system flushed and see if there's any clogged spots in the radiator.
Old Jul 24, 2002 | 12:18 AM
systemguide's Avatar
Check to make sure the fans are working. Seems like when the car is moving it is getting air to the radiator but when sitting in traffic not enough air is heating the radiator to cool it down.
Old Jul 24, 2002 | 12:37 AM
Yup.... check and make sure that your fans are turning on when the coolant temp reaches 100C, according to the cluster. You should definitly be able to hear them blowing when they turn on.
Old Jul 24, 2002 | 09:29 AM
SLK Boy's Avatar
2002 C320
My fans turn on, but not for very long...how can I tell if they need to be replaced? I'm still trying to figure out the same overheating problem...the highest it usually gets to is about 115...it never reaches 120, but it gets pretty close...radiator has been replaced, and the thermostat too....could it be a leaking head gasket?
Old Jul 24, 2002 | 09:05 PM
bklynz00's Avatar
1997 C280
Thumbs up
He thanks for the tips, I think I'll make a trip to the local MB dealer and purchase some Anti freeze and a themostat... I'll keep you guys posted !!
Old Jul 24, 2002 | 09:06 PM
bklynz00's Avatar
1997 C280
SLK Boy
Dont over look your water pump, that could be a problem as well !
Old Jul 24, 2002 | 09:22 PM
BrabusCClass's Avatar
GL450, Sienna SE
My Waterpump went out around 80,000 miles. Also some sort of fuse went out that made my car run hot or something. It was to my fan. Check your fuses.
Old Jul 25, 2002 | 09:31 AM
SLK Boy's Avatar
2002 C320
Oh, the water pump was replaced recently too.. So i'm still wondering why it's getting so hot...if i can't get it fixed, i'm going to get rid of the car soon..
Old Jul 26, 2002 | 08:35 PM
I thought your car is over heating. It's not over heating jus running hot. My 95 C280 does the same thing and someone told me it is normal for it to run that hot, but i'm not sure....
Let us know if you get it fixed.
Old Jul 26, 2002 | 08:46 PM
bklynz00's Avatar
1997 C280
Unhappy
"System-guide" I sure will.. Iam saving up da money now so I can bring my car to the MB dealer for servicing.. lol Iam hoping that your right.. Although, I cant see how it's normal to have the car overheat or get that hot normally while using the AC in stop and go traffic.. That can be dangerous for the engine. It gets hot where I have to cut off the AC and some times put on the heat to get the temp to lower !!
Old Aug 3, 2002 | 10:11 PM
bklynz00's Avatar
1997 C280
Thumbs up
I would like to inform those whom are interested, that I found out what was causing the overheating with my car... The anti-freeze wasnt properly mixed. MB has different mixtures for summer and winter. Summer should be 60% water, and 40% anti-freeze. Once I made the proper change in the anti-freeze, the car didnt reach the 120 red zone as before. Also, I use only MB anti-freeze.
Old Aug 6, 2002 | 08:51 AM
SLK Boy's Avatar
2002 C320
That's good to hear! I think i'll be doing this soon as well (might as well replace my thermostat while I'm at it). Do you know what the mixture is for the winter? I also have a bottle of Red Line Water Wetter...you think i should bother using it, or just use MB coolant and water?
Old Aug 6, 2002 | 11:15 AM
Use 60/40 (Water / Coolant) year round! Unless it gets REALLY cold, I wouldn't worry about it.
And sure, throw in the water wetter... I did to mine. I didn't notice anything, but I guess it doesn't work to bring the coolant temps lower, just dissolves "hot spots" or something like that.
