Problems with my C280, need suggestions
https://mbworld.org/forums/showthrea...threadid=12846
To recap:
1. Make sure the thermostat is working. Might as well change it if you change the radiator fluid (it's very cheap).
2. Use MB coolant, and a mixture of 4.5L coolant/5.5L water.
3. Make sure the radiator is in good condition.
4. Check out this thread regarding changing the viscous fan clutch (as well as other overheating fixes):
http://www.benzsport.com/forums/show...threadid=11918
5. Also, make sure you poly-v belt is in good shape. My had cracks in it, and replacing it actually helped the overheating problem a bit.
6. Might also want to check to see if the head gasket is leaking..this is a common problem on the earlier C280s.
This should help you out...
In the end, my car is still running a bit hot, but from what everyone says (including MB), it's ok. I have 130k on my 94 C280, so it's gone through quite a bit.
As for the brakes, i think that's ABS.
Have you replaced the rotors lately? That sounds like it might be time to change the rotors, and maybe the pads too. Make sure the brake wear sensor is secured.BTW, we're going to have a meet in Edison NJ, probably on 9/21 if you're interested! A bunch of people from benzsport and mbworld are going to show up.
I have a 97 C 280 and I had the same problems. Well with the braking when ya slam on the brakes, the plusating you are feeling I would believe is your "Anti-Lock System" going into effect. Most cars with the Anit-Lock System will do that.
With the over heating problem. I had the same thing wrong with my car. The car would over heat while sitting in traffic, and especially when running the AC. At times the car gotton so hot, I had to shut the car off.... So, I took it to my independant mechanic in Queens, NY. They are good!! They knew what was wrong right away. They replaced my "Temp-Switch" and "ETR-Switch".. And would'nt ya know it... no more over heating. With the parts and labor, it all came to $325. Not so bad working on a Benz. Good Luck !!
