Tranny fluid flush.
Old Dec 4, 2006 | 06:36 PM
BayAreaBenzDude's Avatar
Tranny fluid flush.
After reading muliple horror stories about transmission failures, I have decided to change the fluid in my transmission.
Is it advisiable to change the fluid in my differential as well?
The car is a 99 c230K sedan, with 65K miles on the odometer.
Thanks.
Old Dec 4, 2006 | 07:09 PM
SeaCoupe's Avatar
2002 C230K, 2013 BMW 328, 2015 BMW X5
Thanks.
I have a different frame than you, but I just did the tranny flush on my car. Easy as pie. Only word of advice is not to overfill the tranny. I had 600 cc over the max, and the shifting was weird. Pumped out the overfill, and whoa, a new tranny all together. So, pour slow, and measure alot.
As for the diff, that is a much sturdy unit. I wouldn't do it untill you needed to change your gas filter at about 100k.
E
Old Dec 5, 2006 | 08:21 AM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
It may be just a matter of time.I've replaced a rear seal in the C43 and now I have the same leak in the 00' 230K.
Old Dec 5, 2006 | 12:43 PM
Tranny fluid flush.
[QUOTE=emrliquidlife;1870735]I have a different frame than you, but I just did the tranny flush on my car. Easy as pie.
Do you have DIY instructions / pointers on how to do the tranny flush?
Old Dec 5, 2006 | 09:51 PM
xvvvz's Avatar
C230K
Your luck day "Cinderella Story" as they say:
Transmission flush:
http://www.dezinetech.org/w202/
Differential fluid change (should apply to the 202 also):
http://www.slk32.com/pages/diffoilch...oilchange.html
Old Dec 6, 2006 | 12:21 PM
shadowgriffen's Avatar
is a German Tank
Transmission flush:
the author of that write-up is
Old Dec 6, 2006 | 01:49 PM
Transmission flush:
Thanks for the pointers, I appreciate it. The instructions are literally spoon fed.
Old Mar 23, 2008 | 02:34 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
E
Old thread, but I did my flush yesterday. Easy as pie?
Ha.
FYI- the service sheet calls for Fuel filter replacement every 60K miles, not 100 k. Was gonna do the diff oil, but couldn't find the fill location...
need to check the DVD.
EDIT: Just read the DIY on diff, hmmm..didn't see that fill plug.
Did see a metal hose that went to the top with a cap on it.
W203 may be different.
14mm hex is the same size as the drain plug on a FIAT, Ed.
I'll have to dig mine up.
An auto parts store would have that, as a special tool.
I'm planning to use conventional oil since thats whats in there now.
Old Mar 24, 2008 | 07:40 PM
Pasha95's Avatar
'95 c280 '93 190E '07 C230
Transmission flush
Here are some suggestions: don't forget to drain the torque convertor and when you refill the transmission, only put in 2-3 quarts initially, start the engine and move the shft lever from "D" to "R" several times to run fluid through the whole system and then carefully add remaining fluid. Adding too much initially can cause the fluid to leak out through the pan gasket.
Old Mar 24, 2008 | 09:44 PM
ohlord's Avatar
722.6
transmission I have the calibrated dipstick for $40 delivered stateside with tips and a free pan magnet.mb fluid is a must.
diy on benzworld.org w210 section applies to all 722.6 trans.
