Transmission Fluid?
Another worthwhile investment is changing the flex disc and bushings for the shifter (around $250). This will really make your shifter and tranny feel like new.
Dave
I actually just did the change this weekend. Not to invite flames, but I didn't do a filter change. I'm planning on getting a full filter/fluid change in the next 6 months or so, so this is more of an interim job. I used a Pela pump extractor hooked up to about 10 feet of new (clean) poly tubing, and sucked out about 2 quarts, put in fresh Mobil 1 ATF, drove it for about 20 miles, repeated it, and am planning to do it again later this week. I figure I'll get about 4 out 6.5 quarts switched.
Surprisingly, doing the partial fluid change and getting the fluid level *just right* (took a little time) has made a *huge* difference in the shift quality.
Thanks for the help
Eric
The only hard part was finding the torque converter drain plug. I took off my fan shroud (Two clips on top-just gave me more room). Then I took a breaker bar and a 27mm (I think that was the size)socket. I turned the crank shaft clockwise slowly while I looked at the TC. Eventually I saw the drain plug come around. It is also requires and allen wrench like the trannie plug. Alot more fluid came out of that it seemed! Make sure you go clockwise only when you turn the engine by hand. Drop the pan, then there is two phillips (again I think) screws, maybe three holding the filter in. A bit more fluid comes out, and you are all done! Reverse for install. I like the MB pan gasket. It just sits right in there perfectly!
Have fun.
This is the correct way to add ATF fluid back. Once you have replaced the filter, gasket and reinstalled the AT pan, add about 3 qts of ATF. Then start the engine and fill the remaining ATF (Probably about another 5-6 qts).
Dave
The thing that I have been cautioned against doing by numerous parties is to be somewhat cautious/hesitant to change the fluid if it hasn't been done ever, and the mileage on the car is significantly over 50,000. Apparently, as the fluid degrades, it allows deposits to form in the transmission, which is "ok", as the tranny fluid has lost its detergent properties, and leaves the deposits alone, but when you replace the fluid with fresh fluid, it can loosen these deposits and set then floating about the transmission.
Also, regarding the amount of fluid, you should be careful to not overfill, which could damage the trans.
Good Luck!
On 95 and up models you should refer to your owners manual or call a dealer and ask what kind of fluid to use. I *think* if it's an elctronic tranmission, then you have to use MB tran fluid ONLY instead of ATF. Mine is a 94 so ATF is ok. I'd check the back of the owners manual to see what yours is, or look under the car.
Mine was a 722.4 trannie and can use ATF
If it is 722.6 get the MB fluid only.
Double check this, but I'm almost postive.
I'd bet especially with a MB that not changing the fluid for some time will make a huge difference in performance. I've seen cars slip with dirty fluid/filter until changed.
Also on 95 and up (or 96 and up) the tranmission dipstick is a seperate "tool" you have to buy to check the fluid. The top is a locked unit (or so I've read) that you'll have to pop off yourself.
It's still not that big of a job though. Like I said, it went faster than my Toyota. Especially once I found out how to find the torque converter plug, then it was a breeze.
Don't forget your differential back there. Use gl5 gear oil 85-90 range. Fill plug is allen wrench also and make sure to take the fill plug out first. So you dont' drain it and then realize you can't fill it back up!
The magnet is for debris yes. It is also correct to check your fluid while the car is running and warm. Have fun.
