Problem jump startin my car!!!!!
98 C280
Hey guys first post but tryin to get my 98 c280 back on the road but the battery is completely drained n my trunk will not open plus my mechanical key will not open the trunk is there a way i can jump it under the hood or any ideas!!!!!
Don't
you have a positive jumper post under the hood along the side of the engine bay
If you do hook it up to a charger and key out let it charge overnight on 10 amp setting.MB's hate to be jumped and the load on the alternator makes it unhappy.
Whats wrong with the mechanical trunk key?
ohlord![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
If no charging post you might need to pick up one of those cigarette light chargers that go from car to car lighter and let it charge until you can pop the trunk and get to the battery.
ohlord
ohlord
ohlord
You could saturate the lock with a spray lubricant and wiggle the key from side to side, that will unfreeze the lock. It works for me 95% of the time, allowing access to the boot.
I had this exact same problem, I ended up breaking my key in the process so I had to buy another, the new design provided some leverage on the new blade key so i could turn it way better and that did the trick, got the trunk open
yea try being in this situation while having your car impounded, not a good scenario, I would try spraying lubricant in the lock, my local MB dealer also recommended me to call MB roadside, said it is free and are more savy, and if need be would have the car towed to local authorized mBdealer. problem with me was that the impound lot closed at 5:00 pm and MB roadside cant be called til after 5:30 or something like that, that cigarette battery charger idea is a goodone, wouldnt hurt if all else fails, you could always take it back if it doesnt work.
well good luck!
well good luck!
I put up pictures here that show how to do it:
http://www.club202.com/forums/showth...tery+jump+open
98 C280
thx
Hey guys thanx for all the feedback im sure one of those ideas will work and i can get my benz back on the road !!!! let you know what worked out..
98 C280
some good old liquid wd 40 and a pair of needle noses and some finagling unfroze the lock thanks alot for the help for everyone reply and another 200 spent for a dead battery lol!!!!
