Help me PLZ .... RPM problem w202 c280 1996
I tried the Self-Diagnostic using Automatic Climate Control these errors had been appeard
421---> Engine Coolant blower motor control module
but 421 (Engine Coolant blower motor control module) can't delete
Also i replaced these parts (oil + filter -- gear oil + filter -- thermostat -- i checked all fuses --- Fuel filter --- 6 Bosch Spark Plugs)
i dont have the answer to your question but something to check for, is check all of your tubes from your intake to make sure you dont have a vacume leak as this can cause surging, another thing it could be is your idle control built into your throttle plate/butterfly unit, ive read these can fail and cause your problem
but what you mean by throttle plate/butterfly unit ? do u have a picture for this unit ??
http://www.detali.ru/cat/oem_mb0.asp?TP=1
thats the intake crossover pipe:
the part i was talking about is number 65, it is very expensive and i would want to reccomend changing that part, but ive heard of it going wrong
i want to ask you about the price for this part ??? range of price ??
thank you
i would reccomend geting those problems with the fault codes sorted first.
do lots of searching and reading around relating to your problem, as its quite specific you may be able to find it discussed before, i would search for the idle problem, im not sure if it is from your a/c? it may be just that the a/c puts more load on the engine making it try to compensate, also read around about a bad maf sensor
