OBD2 port location
If it does turn out to be the air sensor, how expensive are they and how easy is the replacement? I am fairly competent with wrenching and have pulled engines before but all of my experience with with carbureted cars.
in the v6 and v8 model you would have a p0170 and p0173 indicating both banks of cylinders affected since you only have one bank of cylinders you only have one code
www.autohausaz.com has them for about 180 delivered
you can try cleaning with crc brand maf cleaner (only) sometimes it works
worth a try
if not you get the new one and spend the 5 minutes to replace it
dealer charges up to 8bills for this simple diy task so don't go there
also don't buy off ebay no matter what the seller says of the cheap prices of their mafs they are fake chinese clones right down to the fake casting numbers.
You can also get your own scanner for 70bucks at harborfreight tools item 94169 coupons for 20% off in most boating and hunting magazines.
The CEl will clear itself when the new maf adapts the ecu. No need to erase the code or disconnect the battery since that will make all the I/M status read not ready and if you have a smog test due shortly you will fail.
labeled CRC brand MAF cleaner complete diy clean is on the can
Don't touch the actual element with anything but the spray no q-tips
Sometimes it helps most times If it helps it will only be for a while and then you will need a new one.
Autohausaz.com best deal I have found free shipping
If your motor mounts are collapsed or leaking autohausaz and it for some reason is common to have 2 different suppliers for l and r
you don't pull the engine you lift it with a block of wood under the pan and a jack enough to remove 1 mount at a time remove bolts lift a few inches replace repeat.
Mounts will feel like a small miss at idle but won't be your real hesitation problem.
If it got worse after cleaning make sure you installed it fully seated and no kinks in the intake tube that might create leaks.
