Need help with manual swap
Old Jan 25, 2011 | 05:33 PM
bagelsjustbagel's Avatar
In search of W222
hey guys, im going to do a manual swap.
my current tranny is on its way out and imma get a good deal on a manual one.
SO.
Transmission needed (717.4 5speed out of a 1999 slk230k )
Flywheel
Clutch
differential extended.
and now for the tricky part. I dont know what else i need ! lol im not a mechanic and...
i need to know what else ill need and wheres a shop that maybe i can talk to abut this?
also i have a 97 amg which means ill need to fool my computer.
how? anyone know of a custom shop that might now? i need heellpppppp. :thumbup:
Old Jan 25, 2011 | 10:44 PM
AcousticplayerJ's Avatar
2000 c230 Kompressor
Well, you'll need a pedal assembly too. I don't think you'll be able to shift without a clutch pedal
Then I think you might also need a new ECU since the current one is going to keep looking for the automatic transmission. I'm not sure if there's a way to reprogram it. But then if you just took the ECU out of the transmission donor car, it probably wouldn't play well with your engine. I think most issues are going to be with the computer.
Old Feb 15, 2011 | 12:46 AM
6speedclk's Avatar
CLK500
What engine is in your car?
Old Feb 15, 2011 | 02:42 AM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
The ECU, Adam, is going to be the biotch
Old Feb 15, 2011 | 01:04 PM
6speedclk's Avatar
CLK500
I put a six speed in a 03 clk 500 and renntech was able to make the changes to my ecu.
Old Feb 16, 2011 | 02:18 AM
23K's Avatar
23K
Thats interesting,i wondered just how easy it would be to dissable the auto tables,how much did it cost you to have done?
Cheers,
Paul
Old Feb 16, 2011 | 11:23 AM
6speedclk's Avatar
CLK500
Cheers,
Paul
Around $450 with no tune. I'll start building power after I get a better clutch. The setup has worked perfectly for 3 months now.
Old Feb 16, 2011 | 11:59 AM
RANDY_P's Avatar
1996 C36 AMG, 1970 LeMans Sport, a truck
This isn't going to end well.
Between the ASR and the rest of the computer it's going to be well past what the average guy can DIY- or at least without straight up butchery.
rjp
Old Feb 16, 2011 | 01:15 PM
6speedclk's Avatar
CLK500
[QUOTE=RANDY_P;4521683]This isn't going to end well.
rjp[/
It is a little complicated but it can be dun. If MB ever made a manual 202 the parts are avalibal. And as for coding it's almost all options. Under trans slect manual (with a star tester). A slk has a vary similar chassy. I bet every part and wire you need would transfer over. With my conversion I used a parts car (01 C240). Every thing transfers over flawlessly. And it was only about 4 days work.
Old Feb 16, 2011 | 09:00 PM
23K's Avatar
23K
Where not the average guy :P
So the 6-speed you have is the one ending in part# 59 01? ...The rare one fitted to the V6 engines?...theres plenty of the other inline engine variant.
Im keen to do a 5.4 with it and just uprate the pressure plate(even though its rated for much less torque),my 5 speed manual in the 202 handled the near 400hp for ages and still runs smooth. would need to do minor surgery for the gearshifter in the 6-speed though.
Do you have any pics of the gearbox before it went in?(or any other parts of the system?)
Can you change gearbox selection from the star diagnostics???(surely its not that simple?)^^
what happened to your cruise control?.
Old Feb 16, 2011 | 11:04 PM
6speedclk's Avatar
CLK500
Sorry I can't post pics. I don't have a computer at home. I only have an iPhone. But the trans shifts from the top thrue one rod.
All I had to do with my 209 is tel the EIS (the ignition swick) that it had a manual trans and the rest of the control units fell in line. But I had to send the engine control unit off because it is flashable. I could vue the coding but couldn't change it. On a 202 you may be able to change it with only a tester.
The cruise control works grate.
Old Feb 18, 2011 | 04:09 PM
RANDY_P's Avatar
So what did all this cost after it was said and done? Also- do you have any idiot lights / CEL on?
Old Feb 18, 2011 | 04:31 PM
6speedclk's Avatar
CLK500
The price of the c240 was $7,200. Shift boot was $200. The ECM was $400. I'm about to buy a $1100 stage 5 clutch. There are no lights on and no codes. I'm still working on the c240. I need the base adaptation to dump into the new trans control unit. That car is coating me a bit of coin. So talking cash about $10,000. But I gat to shift gears and a nice work car out of it.
Old Feb 18, 2011 | 10:25 PM
ohlord's Avatar
Apples and oranges
The C36 biggest issue is that stateside we never got sticks.
You will need to find a European used pedal assmbly.The rest is not all that involved.Just rebuild the c36 auto and call it good. 5 speed conversion could cost more than the old girl is worth.
Old Feb 24, 2011 | 03:33 PM
eundaddy's Avatar
1998 Mercedes-Benz C43 AMG
I think the 5 speed conversion was already done in the UK. I remember a member on club202 was able to fit a c280 5 speed to the C36. I'm pretty sure that the same cannot be done on a C43 though...
Old Mar 1, 2011 | 01:33 PM
lkchris's Avatar
'10 CL550, '12 GL550
There's never been a manual transmission AMG in recent years.
Old Mar 1, 2011 | 04:51 PM
eundaddy's Avatar
the tramontana has an amg v12 and it has a 6 speed.
