Finally 16" RIM upgraded !!
Old May 22, 2003 | 08:27 PM
amdxp's Avatar
C180
Talking Finally 16" RIM upgraded !!
Finally got my 15" rim replaced with this 16" rim, it's a original MB Avantgarde for W203.
Well, it does cost me a bit, but it is NICE !! Mine is only a C180, so I don't need anything more than 16" at all !!
Old May 22, 2003 | 08:46 PM
Benz117's Avatar
95 c280
Nice wheels, planning to drop?
Old May 22, 2003 | 09:51 PM
2~s0L~t's Avatar
1968 cadillac coupe deville calais hardtop
very nice
looks very clean. nice choice man.
Old May 22, 2003 | 11:45 PM
amdxp's Avatar
C180
The car is already lowered plus I suspect my shock is not well (time to change !), the ride is not so well now and will be worse if lower further .
So no more lowering !!
Old May 24, 2003 | 03:51 AM
DougandhisC280's Avatar
2008 SLK-280
THAT'S DROPPED???
Old May 24, 2003 | 11:02 AM
Rincewind's Avatar
1998 C230
maybe the wheels r just too small?
Old May 26, 2003 | 04:05 AM
amdxp's Avatar
C180
Not really !
1. I thought the rule of upgrading the wheel and maintain similar performance is to keep the rim + tyre size same/similar to the stock specs.
2. I also compared with my bro's 18" Brabus + 225/40R18, the height of the rim + tyre are the same as my 16" + 205/55/R18
Old May 26, 2003 | 01:37 PM
2008 SLK-280
I think you meant 205/55/16 which is the right tire size but the car just doesn't really look like it is dropped that much. What size pads are you running?
Old May 27, 2003 | 10:14 PM
amdxp's Avatar
C180
I think I use the thickest pad. At the rear I use non-MB pad, which is even thicker coz' I want to make a slunting effect.
Old May 28, 2003 | 02:02 AM
2008 SLK-280
What springs and shocks did you use?
Old May 28, 2003 | 11:58 PM
amdxp's Avatar
C180
Shock is the original one (suspected defective already).
Spring I have 2 sets, one set original, one set sport, all inherited from my brother when I got the car from him.
BTW, I am using the sport spring now, but have requested the tyre shop fella to use a thicker pad to raise up the back to have the slunting effect.
I have to say the drive is not so good now as the shock is weak already. In 1-2 mth time I must get the shock changed.
Old May 29, 2003 | 12:26 AM
2008 SLK-280
It will be much better with sport shocks. You're lucky you got 2 months out of the factory shocks, I got 11 hours out of mine. What BRAND of springs do you have?
Old May 29, 2003 | 01:17 AM
steve s's Avatar
1996 C36 AMG, 1995 Volvo 850 Turbowagon
don't be surprised about the effects of the thickest spring pads. our c36 sits very high up (huge *** fender gaps) stock... in fact, it's taller than a stock w202 c280 with 17" amg rims only.
Old May 29, 2003 | 04:25 AM
amdxp's Avatar
C180
Unhappy
Wow, given only 11 hours , that was short !!
Well, mine is still "okay" in a way it neither produce noise nor oil leaked from the shock, but it gives a very "soft" feeling. The car shake quite badly after making say 90 degree turn.
Brand of the spring ?? I dunno, I only can tell you it is in red colour. Perhaps I go back and do a check again.
Old May 29, 2003 | 02:41 PM
2008 SLK-280
I predict Eibach.
Old May 29, 2003 | 05:07 PM
2~s0L~t's Avatar
springs
eibach pro kit which is for our cars is black, the sportline is red... dunno if there is an eibach sportline for c180, not for the c280 thats for sure so...
maybe vogtland. they are redder than the __________ on the donkey lady in mexico.
sol--t
