Sun roof shade delaminating
Old May 28, 2011 | 08:48 PM
waybomb's Avatar
SL600 r230, SL600 r129, SL500 r230, ML320, C280 Sport, R170 450SL, 190e 2.3 16V (2)
The sun roof shade, in our 97 C280, has delaminated. The gray covering has separated from the shade, and has pulled out from the vents.
Any body know how to remove the shade and any hints on fixing this condition?
Old May 28, 2011 | 09:33 PM
coors2003's Avatar
99 c230 kompressor
mine is doing the same
Old Jun 19, 2011 | 08:35 AM
jaeski33's Avatar
2008 R350, 1997 C280 SEDAN
sun roof shade
I purchased one for mine last year sometime but not sure how to remove the old one. I think the headliner has to be dropped which sucks bad. I may take it to this upholstery shop locally to do it.
Old Jun 26, 2011 | 06:11 PM
sprat sparrow's Avatar
1997 c 280 (231,000 miles :-)
yes thats right and while they are at it have them change your rubber gasket , over time they loose the bounce then start to allow sound to come through and you loose your surround vacuum on the inner cabin which means you will hear everything you go past or goes past you
same goes with the door rubber seals. Kind regards.
Old Jun 26, 2011 | 06:13 PM
the above advise was given assuming your vehicle has had a few year on the road.
Old Jun 28, 2011 | 07:25 PM
jaeski33's Avatar
Do you know of a part # for the gaskets you are referring to?
Old Jun 29, 2011 | 07:11 PM
Wink
i will take a look and get back to you.
Old Jun 29, 2011 | 08:28 PM
jaeski33's Avatar
Thanks. I only have the shade to replace but I would like to replace the surrounding gaskets etc if you suggest. I will need the part numbers though.
Old Jul 1, 2011 | 01:27 AM
wampa's Avatar
E500 & ML500
I'm also interested in the part number for the sunroof gasket.
Old Jul 3, 2011 | 05:14 PM
Jovsky's Avatar
2000 C230 Kompressor Sport
Sun Roof Removal PT.1 - http://www.youtube.com/user/lucabert...11/DQuB-JSSgvE
Sun Roof Removal PT.2 - http://www.youtube.com/user/lucabert.../5/MvsjIr4e93o
Sun Roof Motor - http://www.youtube.com/user/lucabert.../6/Ecff3kBX02M
Reassembly of the Sun Roof - http://www.youtube.com/user/lucabert.../4/1HuA0JW3UC8
Hope this helps...
Old Jul 7, 2011 | 11:26 AM
jaeski33's Avatar
Originally Posted by Jovsky
Thanks man, this helped me out a lot. It wasn't as easy as the video showed but it did work. I almost hired someone to drop the headliner. You saved me $$.
James
Old Jul 7, 2011 | 01:14 PM
Jovsky's Avatar
James
You're welcome James! That's what this forum is all about, to help each other...
Old Nov 9, 2011 | 11:29 AM
chimchongdlight's Avatar
2013 W204
I still don't get how he did it so easily. I opened the sunroof. Then took off those fasteners. But I got nothing after that. It wouldn't come out
Old Nov 9, 2011 | 03:50 PM
YNVDIZW124's Avatar
lots of cars
It wouldn't come out because there are some tabs on the back of track on the panel that hold it. You need to open the sub roof up and move these tabs down, then close the sunroof and slide it all the way in, then you'll slide the panel out.
I've done it on my car a few times and covered it in suede.
