Old Jun 16, 2015, 01:47 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension
Print Wikipost
Creaking noise from suspension
Old Jun 4, 2003 | 12:09 PM
MidniteBluBenz's Avatar
540 6spd
Lately, my car's been making this creaking noise as the suspension travels. I took the car to the dealership and they told me that because I lowered the car I've caused the noise. Then they told me that I need new upper control arms in front, and need more time to diagnose what needs to be done to the rear to cure the noise.
Normally I would believe what they're saying, but this is the same dealership that once blamed a misfire in my engine to my remus exhaust and not the real problem which was a bad seal around the spark plug firing on the 4th cylinder.
Any thoughts on what the real sourse of these creaking noises might be?
Old Jun 4, 2003 | 02:33 PM
Rincewind's Avatar
1998 C230
they messign with you
creaking noise or clunking noise coming from your front wheels or rear wheels when going over bumps/imperfect roads at high speeds is a symptom i currently have. im riding on stock setup with 60k miles and im pretty sure its bad ball joints.
Old Jun 4, 2003 | 02:36 PM
Rincewind's Avatar
1998 C230
i did sales for high end audio for 2 years and i'd say the same **** to ppl who tried to modify their amps with non-company recommended tubes. i'd tell them their warranty was void and we'd charge you extra to fix it.
Old Jun 5, 2003 | 01:08 AM
dumpsta's Avatar
SLK280(Gone), C63, CLK550
I also have a creaking noise from my suspension while going over bumps. There sound comes and goes. Ball joints replaced and the problem is still here
Old Jun 5, 2003 | 02:33 AM
Rincewind's Avatar
1998 C230
how much did it cost you to replace ball joints
Old Jun 5, 2003 | 02:34 AM
Rincewind's Avatar
1998 C230
hmm. i read in another thread it may be the front or rear sway bar
Old Jun 5, 2003 | 04:09 AM
DougandhisC280's Avatar
2008 SLK-280
Both of my Mercedes stopped creaking when I changed out the shocks.
Old Jun 5, 2003 | 01:19 PM
dumpsta's Avatar
Cost me nothing, dealer replaced the ball joints for free as well as a 'steering dampener' ? I complained about the noise and although my car is out of warranty they did the work for free as a 'good will' gesture or something.
I think they just want me to buy a new car. lol
Old Jun 6, 2003 | 05:43 PM
merclover's Avatar
1996 C220 (W202) and E320 (w210)
LOL ..OMG now who gets a customer service like that on a stealership!???!!!! i couldnt even get the dealer to change the front window velvet thingy for free!
Old Jun 6, 2003 | 05:51 PM
blackmercedes's Avatar
Stop the car and push the front end up and down. If it squeaks, then most of the time, it's the lower front ball joints. This is a frequent repair on W202 cars.
Old Jun 6, 2003 | 07:47 PM
Rincewind's Avatar
1998 C230
tried it
no squeaky
noise is coming from the rear
what could it be? sway bar back there?
Old Jun 6, 2003 | 11:03 PM
msport3's Avatar
1999 C230 Sport Kompressor
Had the same problem on my wife's C240. Dealer replaced the front sway bar.
Old Jun 7, 2003 | 03:28 AM
dumpsta's Avatar
I can hear the creaking noise even when I step out of my car(when the car rises). I believe it comes from the rear.
Old Jun 7, 2003 | 08:25 AM
Rincewind's Avatar
1998 C230
how does one diagnose if a sway bar is bad
and is there a rear sway?
Old Jun 7, 2003 | 02:10 PM
msport3's Avatar
Correction, the dealer replaced the sway bar bushings, not the sway bar. And yes, the W202 does have a rear sway bar.
Old Jun 8, 2003 | 04:03 AM
soldsep's Avatar
87 300 E
check your fender for any signs of rubbing. then come back and tell me if you saw anything. (you need to remove your wheel for this)
Old Jun 8, 2003 | 04:07 AM
henry47's Avatar
asdf
if its a clunking noise, your shocks need to be tightened. sometimes its just chasis stress when going over speed bumps
Old Jun 8, 2003 | 08:30 AM
Rincewind's Avatar
1998 C230
thanks henry i'll have my mechanic check it out when im in for 60k service, got my car booked this friday
Old Feb 14, 2014 | 12:27 AM
lisamhos's Avatar
2006 C230 Sport
2014 issue
I had the creaking noise as well as horrible vibrations when I breaked. (06 c230 sport). I replaced the rotors and put in new ceramic break pads. Issues still there.
Took car in today and pretty much all of my bushings were cracked. Replacing those as it seems to be the culprit for the noise and break vibrations.
Fingers crossed!
Old May 1, 2014 | 03:46 PM
Abeguerrero1945's Avatar
190E 2.6
Smile
