Will 19 x 9.5 inch Lorinzer Replicas fit??
Old Jun 10, 2003 | 08:33 PM
jdub0022's Avatar
Hi All,
I'm brand new to the forum. I stumbled onto it while searching for some wheels. And boy, was I soo happy to find this site, and I read the threads!! The people seem really cool. No haters? Anyway, I'm sure most of you have seen the Lorinzer LM5 Replicas on Ebay. I want to get the staggered set. 19 x 8.5 front, and 19 x 9.5 rear for my 98 C230. I have several questions.
- It says the offest for these wheels are 38mm. But I thought 35mm was the correct offset?
- Will the 19 x 9.5 fit in the rear? And if so, what modifications must be done.
- What is the best tires size, for front and rear....
...When I had my 96 e-class I had 19 x 8.5 245/35/19 front, and 19 x 10 275/30/19. But I'm sure the C class has a slightly smaller wheel well. Hence, smaller tires must be used.
Any help would be greatly appreciated!!!!!
-Jim
Old Jun 10, 2003 | 11:18 PM
Rincewind's Avatar
1998 C230
i think henry has 19"s and he had to roll his fenders
do u plan on dropping your car some?
18x8 is largest u can go on a dropped car with no rolling fenders
Old Jun 10, 2003 | 11:21 PM
DougandhisC280's Avatar
2008 SLK-280
As the MB World Fanatic of the W202 forum I welcome you.
Old Jun 11, 2003 | 10:47 AM
2~s0L~t's Avatar
1968 cadillac coupe deville calais hardtop
as the dealer of the site...
i welcome you as well...
anyhow, ask henry47 or check out the "will 18x9 rims in front thread" for more info. pay attention to scorchie's post. and like i said try to contact henry47 via email or look for his posts.
good luck.
Old Jun 18, 2003 | 10:43 PM
jdub0022's Avatar
Thanks everyone!
Thanks for the replies!! I now know they can actually fit, but I'm trying to figure out if I have to roll the fenders, and anything else I need to do...
Also, how wide can I go with tires in the back? 265/30/19?
I'm still trying to find Henry47....
-J
Old Jun 20, 2003 | 03:47 PM
jdub0022's Avatar
Good news. I found out that the front offset is ET35mm NOT ET38mm... So after all your great advice, I think it;s going to work out!!!
-J
Old Jun 27, 2003 | 05:02 AM
C230Kompressed's Avatar
I drive what I drive
what if i put 19x8.5. whats the lowest i can drop the car with just removing those pads that come with the car. i dun wanna replace springs if i dun have to...
Old Jun 27, 2003 | 11:44 AM
2008 SLK-280
If you want to lower the car, springs are the only way to go. Taking out those shims will make your car lower but handle terrible. Plus if you put those wide tires on it when you hit a bump you will rub. Stiffer springs keep this from happening. Plus you will need sport shocks and an alignment so just put in the other $250 and get some H&R's.
Old Jun 28, 2003 | 03:14 AM
right on. good advice, thanks
