C250TD not wanting to run
Old Nov 1, 2011 | 05:42 PM
Arash Gillan's Avatar
W210
Hi all,
i have a 98 C250 TD, lately finding it very hard to start, the engine is turning over but will not fire. It takes a few long attempts befor it fires up. I have replaced the heater plugs and battery but still no difference.
Old Dec 3, 2011 | 05:38 PM
burt 51's Avatar
mercedes c2.5 td
Thumbs up
Originally Posted by Arash Gillan
Hi all,
air in fuel lines repace fuel lines and put a non retrun valve with a primer blub it work for me car runs so much better
Old Dec 3, 2011 | 11:24 PM
lordofthering's Avatar
2008 ML320 (W164) - 201K Miles
Hi all,
Did you check spark plugs ?
Old Dec 4, 2011 | 12:46 AM
rocbtm's Avatar
'97 C230
old battery?
Old Dec 5, 2011 | 04:24 PM
W210
Thanks, I am sure you are right. I am no too shy with getting my hands dirty but any indication of how complicated is the job?
Old Dec 5, 2011 | 04:26 PM
W210
Thanks for your reply - but it is a diesel and the glow plugs are new
Old Dec 6, 2011 | 01:42 PM
burt 51's Avatar
mercedes c2.5 td
hi arash the job is very easy fuel line runs up the near side of the car. inside the engine bay cut rubber fuel line 5 cm above metal fuel line.put 8mm non return valve in with small length of fuel line then primer bulb suck diesel through to primer bulb and connect fuel back on then pressurize fuel system and start the car hope this helps 8mm primer blub on e bay number 370281352549 and a 8mm non return valve on e bay number 220848135272
Old Dec 7, 2011 | 06:21 PM
W210
Hi Burt, thanks for the tips. I'll get on with it soon as I can as she is getting worse with the cold weather!
