1995 C220 70 mph woes
Old Sep 3, 2012 | 12:00 PM
95c220red's Avatar
1995 C220
I just recently purchased a cherry looking 1995 MB C220 but with a couple of mechanical issues that i took care of myself. After purchase I replaced the throttle actuator, maf, fuel filter, pump and hose. Replaced all vacuum hoses, changed oil and slapped on a set of new tires. Now I'm not getting any trouble codes now but before I had a maf TC and a knock sensor TC. Main reason I replaced the the TA and maf was that I was told that the old parts were causing a condition that prevented speeds over 70 mph. Well still has the problem, it will not climb above 70 mph. Has anyone had this problem?
Old Sep 4, 2012 | 02:17 AM
PelicanParts.com's Avatar
SPONSOR
Answer
I suggest taking it to the dealer, and have them scan for codes.
Have them run the VIN# for campaigns.
roy@pelicanparts.com
Old Sep 4, 2012 | 01:53 PM
95c220red's Avatar
1995 C220
Campaigns??? Dealer is not an option, it's. 17 year old car and the dealer might as well pull a gun and Rob me outright. I am pretty proficient mechanically and must find a solution aside from a MB dealer but thanks for your reply.
Old Oct 5, 2012 | 07:30 AM
Dino X's Avatar
1994 MB C220
Ohh yeah! that's how i feel with some dealers too.. Hmmm… It seems you already covered it all. My best guess is a slipping forward band clutch if you have an auto tranny, or a low performing clutch issue on manual tranny. Or worse you need a new piston rings and valve job. You can also blame a blocked catalytic converter or exhaust system. Try using some famous engine treatment and fuel injector additives for first aid solution or perhaps customized your induction system…
Old Oct 5, 2012 | 09:02 AM
jc1kz's Avatar
2014 C259 Sport MB White Diamond Pearl
Don't get it fixed at the dealership, but at least have them put it on the STAR....this way you get the codes (since you are not getting anything) they should tell you what is wrong, then you fix it on your own, or at an Indie....
Old Oct 8, 2012 | 11:58 AM
SPONSOR
FYI
Campaigns are covered regardless of age.
The MB Star diagnostic scan tool is $28,000.00 per year subscription fee, and does more diagnosis than any other unit, at least on MB.
Average cost is one hour or roughly $150.00 USD.
This is a case of saving money with a correct diagnosis.
Wrong diagnosis can easily cost you $7,000.00 + out of pocket, if the issue is ever fixed.
Old Oct 14, 2012 | 12:02 AM
Village Idiot's Avatar
BMW M3
Faulty MAF. Try taking it apart and cleaning it. If it doesn't fix it, replace the MAF.
Old Oct 14, 2012 | 01:50 PM
SPONSOR
Hmm
He just installed a NEW unit, and it did not change the symptoms.
