new c280 owner with some issues
Old Feb 12, 2013 | 12:11 AM
drakulya1477's Avatar
c280
i just got a 1994 c280, and i found early on the car has problems starting. Usually just give it some gas and a couple extra cranks and it is good to go. The fuel pump is new and i was wondering what else might be wrong (fuel filter/regulator etc). The car very rarely will die when in idle both in park and drive. Any advice would be appreciated
Old Feb 20, 2013 | 12:11 PM
buzzk1ll's Avatar
From: In the spare room in the castle the Mouse has allowed me
1996 C220
Try the cheap way first. Sea Foam it. Could be injectors or idle setting or filter....
Old Feb 21, 2013 | 07:22 AM
aquinob's Avatar
2010 E350, Sold 1998 C230
Any codes? Service history? How many miles on it? Without some more info from you, it's tough to draw conclusions. Is the wiring harness original?
Old Mar 1, 2013 | 11:44 PM
c280
the car has 136,000 miles and to my knowledge the wiring harness is original. i did do a fuel injection clean on it with fuel treatment, it runs better most of the time. When the car is about to die the idle will "search" between 400 rpm and 800rpm.
Old Mar 3, 2013 | 06:58 AM
stefcep's Avatar
w202 c200 sport
MAF sensor?
Old Mar 3, 2013 | 01:39 PM
aquinob's Avatar
I'd strongly suspect electrical which means replacing the harness. Have you checked for any codes?
Old Mar 4, 2013 | 11:11 PM
c280
Only one code and it is for the abs light. Has been on since i got the car. I have a feeling it has something to do with the oversized rims.
Old Apr 1, 2013 | 09:31 AM
taz069's Avatar
chevrolet z-71
Check your crank position sensor!!!!!! Just replaced mine and it cured a bunch of your sounding issues. My lil one is a 96 c280. The old cps had a ohm reading of 1.028, the new one a reading of 1.046 ohm. They were both bosch sensors just one old 195,000 miles old. around 50 buck's from autohaus. Hope this helps.
