Changing Oil
I'm gonna use Mobil1, 10W30 or 5W30... Summer's ending and its starting to get a little cooler at night...
Filter - would Fram be alright? what oil filters do you guys use?
Thanks in advance
used Mobil1 0-40W supersynthetic & filter from the dealer. My '99 C280 takes about 8-8.5 quarts.
http://www.mercedesshop.com/diy_oil_change.htm
timecop369
thanks guys
now how about oil filter? what do you guys use? would fram be alright?
BTW, if you're planning on doing this all the time, you might want to pick up the filter tool from your dealer. I paid about $15.00 for mine and it was worth every penny. You'll need a 22mm socket.
Good luck.
Most Auto Parts stors have generic oil filter tools that will fit MB. I went to an AutoBarn on LI and used their fitting guide to pick out the one that was correct for my W202. I believe I paid about $6 and a 3/8 inch wrench or extention fits in the top.
Good luck.
the generic oil filter socket I bought was a piece of trash. it fit somewhat, but there was too much space in between the cap and the socket so everything I turned it, it would slip. I ended up putting a towel in between and HAMMERING the socket onto it to ensure it's fitment
Possibly different brands have different tolerances. I am sorry you had a bad experience. I have done 4 oil changes in a year and a half without any problem with my generic wrench.
No. Use the OE filter as it has the bypass that allows oil to flow in case the filter gets clogged. Fram are not much cheaper and it's false economy anyway.
(Consequently, cartridge oil filters usually do not have this, as the mechanism is generally not part of the cartridge.)
-s-
As far as oil additives go, I know it says to not use additives but Engine Restore is incredible. Every time I poor it in a car I see very noticeable differences. I poor it in mine about twice a year and have never had any problems. Something has to fill the gaps from wear and tear and Engine Restore deos this wonderfully. I think the manual says not to use additives because most of them just thicken the oil. Restore actually bonds to the seals and conditions them. I think it would be better to have additives and conditioned seals than no additives and worn seals. IMO!!!
http://www.canadiandriver.com/articles/pb/additive.htm
BTW, for those with under warranty MB cars, you void your warranty the moment you pour any of that snake-oil crap in your crankcase.
Most auto parts stores have the filter cap socket. It got mine at autozone for 3 bucks and it works perfectly.
Pretty much every canister oil filter has this. Even WalMart House Brand.
-s-
Beware, not all filters are created equal when it comes to performance. There are differences not only in the filter pore size, but also in the total filtration area (sq. in.) and number of pleats. Also, some filters have cheap media assembly (end caps) that can blow apart and pump unfiltered oil or worse, the trapped dirt into your engine.
Buyer beware!
What kind of differences do you notice? I have seen that stuff advertised in Car and Driver constantly...I may try this myself if I know it's not gonna harm my engine. But from your opinion, seems to work well. Anyone else try Engine Restore?
thats what i've been telling you i've been adding.... its *******g amazing, you definitely notice a difference. i honestly think it helps and doesnt do anything. i mean if they can afford an ad in every car magazine every month, they must be doing a good job, no?
I went to my stealership and they said that the oil filter tool is back ordered nation wide. Is there something else that I can use to remoce the filter cap?
I've used things like: hands, rubber sheet, pipe wrench. They all seem to do the same job.
-s-
Every filter designed for a particular make and model will have the necessary components (anti-drainback, bypass, etc.) if required regardless of the filter brand. Some filters include a safety bypass even if not called for by the manufaturer. They do this to prevent the filter from bursting due to overpressure.
-s-
thanks for backing me up! but you should have responded to the dissenter instead of to me.
-s-
