rear bose sub issues
Old Jan 1, 2004 | 08:24 PM
ricerokets4life's Avatar
recently, ive noticed that the rear speakers have been causing a rattling noise when playing at lower frequencies for bass notes. ive narrowed it down to the rear passenger-side one. i took off the speaker cover and looked for any signs of trouble. i took a look at the sub to make sure it wasnt blown and looking from above, it seemed alright. then, i tried pushing and pulling on various objects in the vicinity of the sub, from above the rear shelf and through the trunk, to make sure nothing of that sort was causing the rattling; nope, nothing like that. any suggestions?
Old Jan 1, 2004 | 09:08 PM
ryhi's Avatar
UCF21
my rear deck used to rattle due to the first-aid compartment. i just stuffed it with like 2 shirts....atleast i got no more rattle!!
Old Jan 1, 2004 | 09:48 PM
ill try that out. i had to take out the kit because the bolts for my cd changer are in its way.
Old Jan 16, 2004 | 02:49 PM
narci's Avatar
It's the Third brake light i believe that makes ther rattle.
Old Jan 18, 2004 | 08:40 PM
davis449's Avatar
2016 BMW Z4 sDrive35i M Sport
Had the same problem in my 95 and I pion pointed it to the rear passenger side of the ca in the trunk. Shoved some paper towels between the metal plate and the shelf and it solved it.
Old Jan 18, 2004 | 09:51 PM
metal plate? all ive been seeing is the plastic grill while looking up through the trunk on the bottom of the speaker. can you explain where the metal plate is?
Old Jan 19, 2004 | 03:37 PM
davis449's Avatar
OK, well, mine's a 95 so maybe they did away with that after 97. In my car there's a metal plate that runs the entire self (in the trunk looking up) and the speaker is mounted in between it and the shelf. That's where I pin pointed my rattle.
Old Jan 19, 2004 | 05:24 PM
ok thanks ill take a look. the only thing metal i recall seeing was the rear shelf itself lol.
