c200 1994 is it HMF or PMS
Old 12-17-2016, 03:13 AM
Kanishka Prasad's Avatar
c200
so why doesn't my scanner give me any data when i plug it into the 38 pin socket !! ?? !!
Old 12-17-2016, 03:21 AM
c200
pins allocated in the 38 pin connector
pin
1
2
3
4
6
16
17
30
Old 12-17-2016, 06:40 AM
Russell Ormerod's Avatar
not a merc
What tester are u using?
Old 12-17-2016, 06:45 AM
not a merc
Make and model of tester
Old 12-17-2016, 10:27 AM
c200
this model !! i dont have high end scanner tool !!
Old 12-18-2016, 01:30 AM
not a merc
It seems to me that your scanner is only capable of reading OBD pids. Which are a waste of time for any serious diagnoses. You need A tool capable of reading proprietary protocol and data. Something like a launch. What country are u in? Maybe a nearby workshop can help u read the values
Old 12-18-2016, 11:05 AM
  #32
c200
well im in srilanka !! so what launch model will help !! and i cant move the vehicle at all !!
Old 12-18-2016, 12:18 PM
  #33
c200
http://www.ebay.com/itm/Launch-Creader-VII-OBD2-diagnostic-Scan-tool-Transmission-ABS-Airbag-SRS-Engine/391654567001?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D38530%26meid%3D8de49228d6cd4746857fd4135cca1bc7%26pid%3D100005%26rk%3D2%26rkt%3D6%26sd%3D152358138338
will this work
Old 12-18-2016, 03:51 PM
  #34
not a merc
It looks like it can. I have the launch x431 and that works well.
Have u checked your overvoltage protection relay if all outputs are ok. And fuse 23. First restore power on black red wire to vvt solenoid
Old 12-19-2016, 01:49 AM
  #35
c200
Then il have ti make an order for the new scanner ! Okay ill check the wis and ill find whats causing the problem ! And yes i checked the voltages at the Over load relay ! And its working fine ! Relays are alsoo working
Old 12-22-2016, 06:54 AM
  #36
c200
russel do u have the wiring diagrams in the TB !! i wanna recheck if its rewired correctly !! i doubt it again !! because my loom didnt have nay other coating all were were in contact so multi meter readings are a doubt again !!
Old 12-22-2016, 01:48 PM
  #37
not a merc
Ok no problem. I will check my notes at work and send it to you
Kanishka Prasad (12-23-2016)
Old 12-23-2016, 12:49 AM
  #38
c200
IN WIS the cam solenoid gets power from k40/4 relay module but i cant find that relay in this model !! any idea ?
Old 12-23-2016, 02:40 AM
  #39
not a merc
Your year model does not have k40. Look at lf fender next to Abs pump. There is a plug x26/25 look for plug B pin1 black red wire. That is power. I think it is wired to overvoltage relay . From fuse 23.
Old 12-23-2016, 02:53 AM
  #40
c200
yes i saw that but where does it lead to !! the fuse box ? !!
i referred the Pe 07 51-p-2000-99k document in WIS as what i showed for my VIN number !! is this correct for my model !!
Old 12-23-2016, 06:09 AM
  #41
not a merc
I will have to look.
Old 12-23-2016, 06:13 AM
  #42
not a merc
Diagram of throttle body
Old 12-23-2016, 07:39 AM
  #43
c200
ohhh my wiring is the same !! thanks alot russell !! thank you for ur time !! and i went in dept about the cam solenoid connections
in the connector you said !! the pin 1 and 2 are the cam solenoid connections and this wires leads to the fuse box but not to the fuses but it connects to a socket which again goes inside the cabin along with the big harness
Old 12-23-2016, 09:10 AM
  #44
not a merc
Connector B pin1 is power it goes to fuse box yes but it is unfused check if u have power at fuse box on red black. Possibly ends up at ign switch.
Old 12-23-2016, 09:28 AM
  #45
c200
okay but as in the diagram it must go oto ECU pin 1 on section B and one end to the k40/4 relay !! weird :P
Old 12-23-2016, 10:10 AM
  #46
not a merc
No mate. Look at pe07.51-u-2000-99wf
The diagram U looking at is for the later version.
Unless I am wrong? Do you have a module box? Ecu housed in a sealed plastic box with diagnostic plug inside? I think not.
Old 12-23-2016, 10:20 AM
  #47
c200
no my ECU has the aluminium box !! which has screws !! and i checked my wis program shows only this document for my VIN !! and i did a document search and its no result found ! :/ duuhh !!
Old 12-23-2016, 10:35 AM
  #48
not a merc
Wis is not like epc. U need to look at the as of and up to dates on the diagrams. Use the diagram I refer to. When I talk about a module box mean a black plastic sealed box with a lid on it. Under the lid u will find HFM ABS and the k40 relay module and the diagnostic socket. U don't have this version? K40 and module boxes were only for later c200 240 models Tec not c220
Old 12-23-2016, 10:37 AM
  #49
not a merc
Don't use full bin in wis just enter 202022 then group 7 wiring diagrams
  #50
not a merc
Meant vin not bin, sorry
Quick Reply: c200 1994 is it HMF or PMS
