Shock recommendations for B&G springs?
Old 01-10-2018, 04:16 PM
blackedoutaudi's Avatar
benz
Hello, I'm trying to get as low as possible without coilovers. From what I've gathered, the B&G springs drop 1.6", and the H&R drop 1.4"/1.3". I assume I will need to get #1 pads all around to get even lower. With that said, I decided to go with the B&G, but I'm not sure which shocks to get. I saw a few from koni, ky, bilstien, some with external adjustments, and some without. Does B&G springs work better with one of these specific shocks, or does it matter? Any recommendations? Thanks in advance
Old 01-17-2018, 07:46 AM
Justin Nukis's Avatar
‘99 MB C230, ‘95 MB E300
This is B&G with Bilstein Sport shocks
Bilstein Sport yellow shocks ����
Old 01-17-2018, 07:49 AM
benz
That looks sick. After research, I've decided bon the b&g springs or the eibach.
Old 01-17-2018, 07:50 AM
benz
double post
Old 01-17-2018, 10:06 AM
jnukis79's Avatar
1995 MB E300D, 1999 MB C230
Depending on how low you want to go, stick with the B&G. I've never been impressed with the Eibach.
Old 01-17-2018, 04:32 PM
benz
How would you compare the two?
Is that your car? If so, what spring pads were used, and are those 17" or 18" wheels?
Old 01-18-2018, 12:11 PM
jnukis79's Avatar
B&G if you want the look in the picture above, Eibach if you want to lower it slightly more than stock. OEM spring pads looked up with the VIN #, and they are 17" wheels.
Old 01-18-2018, 12:14 PM
benz
I thought eibach goes lower than the b&g. I understand OEM spring pads, but which size, they make like 4 or 5 different thicknesses.
Looks good with 17's, that's what I want. 18's ride a little rougher
Quick Reply: Shock recommendations for B&G springs?
