Air bag suspension anyone??
Old May 13, 2004 | 01:15 AM
djdoubleg413's Avatar
95 c280
i was wondering if anyone has done or thought about bagging a w202? it looks easy enough. pop the spring out then bolt in a bag. it looks like there is enough clearance so the bag doesn't rub anything. anyone got any suggestions or pros and cons?
Old May 13, 2004 | 01:17 AM
pointman's Avatar
a car that can't do the throttle reset.
bags are really unreliable for everyday use.
Old May 13, 2004 | 08:56 PM
ShollyC220's Avatar
C220
Ahoepter, you still never told me why you are on probation... why?
Old May 13, 2004 | 11:04 PM
pointman's Avatar
first of all, it is "ahopeter" not "ahoEpeter".
second, why are you so curious?
third, i already told you...people dont like it when i tell them the truth.
Old May 14, 2004 | 12:22 AM
DougandhisC280's Avatar
2008 SLK-280
yes it can be done. I've seen it first hand.
Old May 14, 2004 | 01:31 AM
pointman's Avatar
theres no question it can be done, but the real question is why? are you making a showcar thats only gonna see the inside of the garage and shows?
Old May 14, 2004 | 04:32 PM
henry47's Avatar
asdf
i would do it if i found a reliable shop that knew what they were doing. A lot of shops in So. Cal do it and they tell me it puts a lot of stress on your suspension, thus making it vulnerable to break.
Old May 14, 2004 | 09:18 PM
vas2vas's Avatar
87 190E 2.6/1995 M3
airbag suspension is not at all alien to mercedes, at it had widely used an airbag self leveling suspension setup in the past, mostly on the back of old 70's and early 80's S-class sedans (cooled by alcohol I believe), and w123 wagons... Most owners converted to regular springs and gas schocks once they went bad, and I've seen what happens when the suspension collapses, not a pretty sight...
as far as your application is conserned, it can probably be done, depends on how much you're willing to spend... if you want it done for mixed racing/street use, an adjustable coilover kit would be more appropriate...
Old May 15, 2004 | 12:49 AM
pointman's Avatar
the self leveling is completely different from bags. slef leveling is extremely subtle, bags are who drops and lifts in a second or seconds(depending on which kit you get).plus with a real bag set you replace everything...shocks, springs...etc.
Old May 15, 2004 | 11:39 AM
vas2vas's Avatar
87 190E 2.6/1995 M3
my friend has a 1980 50SEL with factory adjustable 2 axle airbag suspension (gray market import from germany)... the ride height difference between the settings was anything but subtle....
Old May 15, 2004 | 11:53 AM
Brunelleschi's Avatar
In the market
It can be done, it is not all that hard to do, and when done right is very reliable. I have had air bag suspesnsions on all kinda of vehicles...I wouldn't do it to my benz though...just seems kinda ghetto for a car of that stature.
Old May 15, 2004 | 07:06 PM
pointman's Avatar
i should have been more clear, i meant the speed... self level is slow , and the airbags are almost instantaneous.
Old May 15, 2004 | 11:46 PM
95 c280
if anyone has any pics of a w202 with bags could you leave a link. any pics would be cool but if anyone has any construction pics of the suspension thats would be nice. and bags aren't as unreliable as everyone is saying on this forum. my other car has air cyliders which are worst than bags and i have put over 20 thousand miles on them. if you do it right it's not a bad setup. and the *****es love front back side to side, and some sparks here and there. thanks
Old Aug 2, 2017 | 11:09 PM
rodney reyes's Avatar
w140 1995 s420
My wife's bagged 202 yes it's possible. Fairly easy
My bagged 140
Old Aug 2, 2017 | 11:11 PM
w140 1995 s420
Don't drive this low although does it nice parked lmao
My old set up on oz Mae wheels
