Here are my wheel pics with H&R, #2 (9mm) front, (17mm - largest available) rear.
![Cool](https://mbworld.org/forums/images/icons/icon6.gif)
It's hard to see but the front has a hair less than 1" gap and the rear
has exactly a 1" gap on level ground.
Sure can. I'll take it tomorrow and post when I return home from work.
Your drop is perfect
Hey man your drop looks great. I want to ask you what I should do to my ride. I have a c280 dropped with h&r springs too. 1.4 inchin the front and 1.3 in the back. I have 18ch rims on it. The car rubs alot in the front on turns and hops too when driving. I got bigger pads for my car but would you suggest something else.
![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
A couple of questions: What number pad is in the front? What series tires are
you using (i.e. 225/35/18 etc.)?
Originally Posted by htc280
Hey man your drop looks great. I want to ask you what I should do to my ride. I have a c280 dropped with h&r springs too. 1.4 inchin the front and 1.3 in the back. I have 18ch rims on it. The car rubs alot in the front on turns and hops too when driving. I got bigger pads for my car but would you suggest something else. ![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
The pads that are on the car right now are the stock pads that comes with the car but I have the biggest pads that is are mad for my car that I have to install and about the tires I have to check on that because I dont know.
2007 CLK350 Sport, 2006 E320 CDI, 1978 Cessna 152
trbo, I have been thinking about lowering my c230 especially after seeing your pics. However, I do have a couple of questions you might be able to answer. 1) do you notice any rubbing with the car lowered at all? and 2) do you have to be careful when you enter a driveway or go over a speed bump so that you do not hit bottom? Many thanks!
front and the largest in the rear (17mm). Also, I haven't noticed anything when pulling into my driveway or general driving around town; to work etc.
