can u guys help my buddy out, i cant seem to figure it out
Subscribe
Nov 17, 2004 | 12:55 AM
okay bul freind has a 96 C280, and at idle the Rpms are straight but the engine feels liek its running kinda rough , and when he puts it in reverse it takes sum gas to get it going in reverse, and it kinda jerks when it goes in,..? any help guys i cant seem to figure out what the problem is for him
Reply 0
Nov 17, 2004 | 01:18 AM
Maybe he should get a cl type s ... much more relaible .... lol
Reply 0
Nov 17, 2004 | 04:58 AM
Quote: okay bul freind has a 96 C280, and at idle the Rpms are straight but the engine feels liek its running kinda rough , and when he puts it in reverse it takes sum gas to get it going in reverse, and it kinda jerks when it goes in,..? any help guys i cant seem to figure out what the problem is for him
How many miles on it? Has the Mass Airflow Sensor ever been replaced? It happened to me but with hesitation big time and my car had 36k on it when it
failed.
I think 96 should have an OBDII port (someone please confirm). I'd hook up a scan tool to it and see what's failing (instead of us guessing).
Reply 0
Nov 17, 2004 | 11:21 AM
Quote: How many miles on it? Has the Mass Airflow Sensor ever been replaced? It happened to me but with hesitation big time and my car had 36k on it when it
failed.
hey trbo2nr, how's it going?
haven't been able to "pursue" my mods, been busy with other stuff.
you're right, 96 c280 is obdII. i looked at the emissions plate on my car, and it does say obdII compliant.
it does sound like a mas/maf symptom. good luck.
Reply 0
Nov 17, 2004 | 04:39 PM
see my reply
Quote: Maybe he should get a cl type s ... much more relaible .... lol
see my reply to your post on "Which Car SHould I buy"- no more of this please
-sholly
Reply 0
Nov 17, 2004 | 04:56 PM
That's a $250 - $350 part. Let us know how it turns out.
Reply 0
Nov 18, 2004 | 09:36 AM
Change your MAS. It is a easy 15 min job.
Reply 0
Nov 18, 2004 | 12:30 PM
i would say MAS. As far as reverse goes giving it more gas than it feels like it should need is normal(not the jerk). my c class does this and my old 190e did it as well. I thought you were a Mercedes tech, shouldn't you know this?
Reply 0
Explore
Nov 18, 2004 | 02:26 PM
Quote: i would say MAS. As far as reverse goes giving it more gas than it feels like it should need is normal(not the jerk). my c class does this and my old 190e did it as well. I thought you were a Mercedes tech, shouldn't you know this?
I am not a MB tech and do not claim to be. If you search this issue on this board you will see that 90% of the people fixed this issue with the MAS. Also follow this link and it will help you with further issues. This will be the best 100 you can spend
http://www.mercedestechstore.com/w202.htm
Reply 0
Nov 18, 2004 | 02:57 PM
Benzman, my bad for not being more clear, but the tech comment was not directed toward you. The thread starter, Euro said he was an MB tech in other threads, so I was directing it to him. Sorry for any confusion.
Reply 0
Nov 18, 2004 | 06:25 PM
Quote: Benzman, my bad for not being more clear, but the tech comment was not directed toward you. The thread starter, Euro said he was an MB tech in other threads, so I was directing it to him. Sorry for any confusion.
No prob...I was not upset.
Reply 0
Nov 28, 2004 | 10:54 PM
hi euro,
while the mass airflow sensor is a weak point on our cars, i would always start with the basics, when is the last time the plugs were changed? i would test the plug wires, make sure the air filter and fuel filter are clean, and check for any vacum leaks before i shelled out too many $, is the check engine light on?
hope it works out to be somthing cheap, my guess is plugs and\or wires.
Reply 0
Subscribe
Currently Active Users (1)
