W203/CL203 Suspension (Shocks/Springs/Sway Bars) Discussion/Upgrade Thread
SubscribeMBWorld Fanatic!
Quote:
1. durability (i dont want other parts to wear out quickly b/c of a unbalanced setup)
2. comfort (i want the ride to be comfortable like stock)
3. performance (duh....)
my budget range is 600-1300 and i am deciding to do suspension instead of bixenons because that can wait. (of course i dont want to spend my max amount if i dont have to!)
a few ideas from reading around:
1. eibach lowering kit
2. H&R cup kit
3. Bilstein Sport Shock/H&R Sport Spring combo
4. KW V2 coilovers
5. H&R coilovers
some maybe out of my range... but if i go for something more expensive, i will probably plan to install myself to save money.
any suggestions for the best value for the price if my goals are comfort, looks, and peformance? (i doubt i will adjust after they're on)
**i also noticed that some people change their pads i guess for ride height?... but anyways, i dont want to do more than i have to
1) keep alignment in place and they should last....Originally Posted by midnight kompre
ok... so i've read though about 4 pages of this thread and wanted to get some feedback. i know there are alot of options out there and i'm not sure if its worth it to dish out for coilovers. here are the three things i value in order:1. durability (i dont want other parts to wear out quickly b/c of a unbalanced setup)
2. H&R cup kit
4. KW V2 coilovers
5. H&R coilovers
2) get the KW V2 so you can adjust the dampening
for comfort, get an adjustable coilover.
for looks, well it doesn't matter unless you are looking underneath the car.
for performance, get an adjustable coilover.
i'd say go for the KW V2
BTW, you don't use spring pads in a coilover install.
thanks rlee... i think i will probably go with the KW V2... but eibachs sound tempting... b/c i would save money and people say its a comfortable ride, but i dont know if its comfort is comparable to KW V2
plus do you know if either ride height or dampening adjustment on the KW V2 can be done easily? (w/o mechanic and by myself?)
eibachs are not adjustable...Originally Posted by midnight kompre
thanks rlee... i think i will probably go with the KW V2... but eibachs sound tempting... b/c i would save money and people say its a comfortable ride, but i dont know if its comfort is comparable to KW V2plus do you know if either ride height or dampening adjustment on the KW V2 can be done easily? (w/o mechanic and by myself?)
for the KW's, to adjust height, in front you just take off the wheel, but in rear you need to take the spring out. (only 1 bolt)
to adjust dampening, in front, you open the hood and twist the knob on top of the strut. in rear, you twist the knob in the trunk, under the trunk liner, on top of the strut.
thanks... its good to know that dampening can be adjusted easily... maybes me more likely to get the KW V2'sOriginally Posted by rlee02135
eibachs are not adjustable...for the KW's, to adjust height, in front you just take off the wheel, but in rear you need to take the spring out. (only 1 bolt)
i know that eibach's aren't adjustable.. i just thought that they may be less hassle and may give a decent result for a better price.. but i cant say b/c i haven't experienced them myself.
don't under estimate the performance of the spring and shock combo. They can perform just as well as coilovers.Originally Posted by midnight kompre
thanks... its good to know that dampening can be adjusted easily... maybes me more likely to get the KW V2'si know that eibach's aren't adjustable.. i just thought that they may be less hassle and may give a decent result for a better price.. but i cant say b/c i haven't experienced them myself.
Quote:
i actually prefer to do a spring and shock combo b/c it seems like less hassle. do you recommend a setup that has good comfort, is durable, and lowers at least 1.5 inches?Originally Posted by FrankW
try H&R or Eibach springs. OEM shocks should be fine, but if you want, upgrade to Koni or Eibach
I would say KONI shocks for sure for the damper adjustment. H&R will give it a softer right and Eibach will give a stiffer ride because of the spring rate difference. It's your call.
ExploreMember
Is that the way you adjust the height for other coilover brands? By removing the wheel? For example with tein basic COs or H&R cup kits, etc?Originally Posted by rlee02135
Quote:
yep, all the sameOriginally Posted by T.O_c240
Is that the way you adjust the height for other coilover brands? By removing the wheel? For example with tein basic COs or H&R cup kits, etc?Thanks
Quote:
yes and no the H&R cupkit are not coilovers.Originally Posted by T.O_c240
Quote:
Originally Posted by drexappeal
Well, don't get too used to it on MBWorld..
hehe, some people just rather wait for an answer than search, they should know better. Well for the guy who was waiting for an answer this whole thread will give you wealth of info on your question. I was ok to ask since after reading pages and searching this forums i couldnt find an accurate info for my 4matic. i was lucky enough Frank was bored to hook it up so dont feel we get special treatment.
choosing suspension is like getting new wheels it a freak headache and a big Task but good luck on your choice.
Coilover = Adjustable Height & Dampers If Available
Cupkit Or Pro Kit = Lower ride NOT Adjustable with Matching Springs & Shocks
Springs = Lower ride with JUST Springs but using your stock Shocks
Quote:
what do you want to adjust?Originally Posted by tsedeng
How do you adjust the pss9s?
Quote:
I would have to disagree. The first time I lowered my sedan I used Eibach springs on stock shocks with #4 pad in the rear. The drop was very mild, but pretty even all around like the 04.5+ sport sedans, though the ride quality was horrible. I ran like that for about six months and switched out to H&R cup kit for a bit more aggressive drop. The matched spring/shock combo provided a MUCH improved ride quality and performance, but the rear was much lower than the front, so I had a half coil cut off the front springs to even it out. After about a year, the H&R setup started getting soft and since TEIN had just released their coilover kits I figured I'd try out the Basics and it was love at first drive! I got the drop dialed in perfectly and the ride was "comfortably stiff". After my sedan was totalled, I picked up a CPO'd coupe and had the TEIN Basics installed as soon as I drove it off the dealer's lot. My advice: don't cheap out...spend a little extra and mod it right the first time.Originally Posted by rlee02135
I just recieved my PSS9s, and all the suspension componenets are in the box, but no adjustment tool. There should 2 tool correct ?
a height adjustment spanner for the upper height adjustement ring
and a height adjustment spanner for the lower height adjustement ring
Is this correct ?
Steve
Is this correct ?
Steve
Saprissa
close
- Join DateJun 2003
- LocationSan Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
Liked:4 Times in 4 Posts
my CARLSSON RS / BILSTEIN PSS9 kit came with the 2 spanner tools.
Carlos
Saprissa@aol.com
Carlos
Saprissa@aol.com
how different is the ride when compareing the sport suspension with tein basic??
Hey guys, I was browsing around on Ebay and saw the guy with the Tein lowering springs listed for $192 + $5 shipping. I made him a Best Offer thing of $175, and he accepted...and it's binding, so I guess I had to pay him. I was kind of planning on waiting until after I got rims to buy the springs, but my ADD veered off the plan. My question is: should I put on the springs when I get them (I have stock rims) or should I wait until I buy a set of nice rims?
question about tein basic coil overs with TSW bremma's: can u do an agressive drop with these rims, or will the coilover be in the way? i dont want an gap in the front or rear, not tucked but you get the point. any help will be appreciated.
Super Moderator Alumni
drexappeal
close
Quote:
Read through the thread and you'll see the common offsets people are using with TEIN Basic's. You can also take a look at the Aftermarket Wheel thread and that'll give you a good idea as well.Originally Posted by JDitlaia
i did cant find the offset for the bremmas prob. just gonna go with h&r right now and cut half a coil in the front. also a question cant you just cut half a coil yourself with a hacksaw, or would i need a special tool and shop to do it?
Quote:
people usually drop the car first, then get the wheels.Originally Posted by kevblah
besides, it'll look better than with stock suspension
