W203/CL203 Suspension (Shocks/Springs/Sway Bars) Discussion/Upgrade Thread
Rating: Thread Rating: 6 votes, 5.00 average.
Old 04-14-2008, 12:55 PM
  #776
moosejaw's Avatar
none
heres the best picture I could take while on the floor of my garage,
My mechanic confirmed there was no perch pad with my original set up and this was the only way it could be installed.
Now my question is do you think bc these came off a wagon they sit this high?
Thanks for you help everyone, i will get to the bottom of this. And sorry to hijack this thread
Attached Thumbnails W203/CL203 Suspension (Shocks/Springs/Sway Bars) Discussion/Upgrade Thread-wr-4.jpg
Old 04-14-2008, 06:58 PM
  #777
tj40's Avatar
C320 Sports Coupe 2003
Maybe the Wagon c/o set uses a stronger rear spring (to help compensate for the potentail extra weight when the wagon is full) and hence the springs sit higher with less weight on them.
I note the H&R part numbers are different for the wagon and sedan versions of the coil overs, (29367-2 Wagon vs. 29367 sedan).
BUT....seems like a big difference to explain by just the springs being a bit stronger..
Maybe a email to customer support would give you the answer?
Old 04-14-2008, 07:16 PM
  #778
moosejaw's Avatar
none
if that's the case, maybe a new spring for the sedan would work?
I can put a call to my buddy at Wheels Boutique in Miami.
Old 04-15-2008, 10:16 PM
  #779
Super Moderator
splinter's Avatar
GMC - Miata - Trek - P-Car
BigAlC230K - In response to your PM, I took the liberty of posting the numbers here in case anyone else needs the same parts. The links (#50) and their respective nuts (#60) are either 10 mm or 12 mm. The sports suspension package, option code 486, is supplied with the 12 mm parts.
There’re inevitably some odd variations and exceptions throughout the model run, so it’s probably prudent to measure their thread size first if unsure. Incidentally, the left and right hand links are the same part.
W203/CL203 Suspension (Shocks/Springs/Sway Bars) Discussion/Upgrade Thread-w203frontanti-rollbar.jpg
Links:
203 320 28 89 10 mm
203 320 29 89 12 mm
Nuts:
N913023 0100002 10 mm
N913023 012002 12 mm
Old 04-16-2008, 12:34 AM
  #780
maecclass's Avatar
2005 C230 K and 2009 Smart
slam it like this wagon
Attached Thumbnails W203/CL203 Suspension (Shocks/Springs/Sway Bars) Discussion/Upgrade Thread-cimg6925od0.jpg
Old 04-16-2008, 02:25 AM
  #781
MBworld Guru
FrankW's Avatar
white and whiter
spring rate difference wouldn't cause that much difference in ride height (1") as you described. coilover springs are not suppose to settle especially when they are already used. over the spring's life time it may settle less than 1/4" and that would probably be consider a bad set of springs.
If you only had the springs previously with the stock shocks then you should have the spring pads in there no matter what. the only other scenario i could think of is that the actual adjustable perch for the wagon is different than the sedans. which could be why even at lowest setting the perch itself is still thicker than the perch used by the sedans.
If you have a jackstand you can lift the car up. take off the lower suspension arm bolts and slide the springs out. the jack needs to have pretty good ground clearance or you won't have enough room btw.
Old 04-26-2008, 04:01 PM
  #782
Marky Bends's Avatar
c320
Hey guys,
Anyone know if I have to concern myself with rubbing of c/o against tires if I install Tein Basic c/o's on my car with Brabus V's ET35 all around?
I thought I might have read it somewhere but wanted to see if anyone knew for sure.
thanks!
Old 04-28-2008, 03:34 AM
  #783
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort (What the heck, it gets 38 mpg!)
Originally Posted by tj40
OK so I'm puzzled. If you go to the Tein website and look at the data the spring rates on their coilovers are all listed at 336/448 lbs/inch (front/rear) for all models (sedan and coupe).
The springs (if you just get the lowering springs) are listed at 146/476 lbs/inch for the sedan and wagon and 112/453 lbs/inch for the coupe.
This maybe a newb question but why are the fronts seemingly so soft compared to the coilovers? I understand coilovers will be stiffer - but X2?? and the rears stay at about the same rate. Is this right or is this a mistake in their data?
Stock front coupe springs are just slop!
Junk junk junk!
Bobbing around like a whale.
I cut 5 minutes off my commute when I 1st replaced springs, due to not fighting to stay in the seat (along with AMG sways) CO's are even better, but yeh, stiff.
Old 04-28-2008, 12:08 PM
  #784
Blake P's Avatar
'09 A4 S Line
Originally Posted by Marky Bends
Hey guys,
thanks!
Most likely you'll have rubbing issues. Recommended offset for coilovers is ET28-32 up front.
Old 04-28-2008, 03:23 PM
  #785
c320
Thanks once again Blake!
Now what? Get 5mm spacers or just go with s-tech springs?
blech..I think I know the answer.
Old 04-30-2008, 12:39 PM
  #786
bkbenx's Avatar
2002 c320 wagon
I have a wagon and I just installed a suspension that came from a C32 AMG sedan. I can tell you that the rear sits way lower than the front on my wagon. I've also heard that the wagon is heavier in the rear than the sedan.
I'm thinking of getting coilovers to get the correct lowering. How's the ride on those H&R coilovers?
Old 04-30-2008, 01:14 PM
  #787
BigAlC230K's Avatar
2005 Mercedes Benz C230K SS
I love 'em! I was skeptical at first bout doing this to my car cause I thought I'd be bouncin all over the place! Not the case. The ride literally almost feels like stock.
As a matter of fact, I've noticed probably after they've settled my drop is a little un-even so I'm gonna take it back in to have it leveled again.
Old 04-30-2008, 02:18 PM
  #788
bkbenx's Avatar
2002 c320 wagon
On H&R's website they note something about variations to height due to manufacturer's shim perch. But you guys are saying that you don't use shim perches with coilovers. Is this correct?
They also say something about needing spacers. How can I check if spacers are needed? I'm not using spacers on the wheels I have now which are Carlsson 1/6 EVO 18x8.5 front & 18x9.5 rear
Old 05-05-2008, 07:43 PM
  #789
dharada's Avatar
Sport springs lower than C240 stk springs?
I just purchased some '07 17 inch rims and tires from a friend's C2?? sport model and installed them on my '04 C240, with 16 inch rims. They are nice!
My C240 needs to be lowered! My stock C240 needs to be lower so I'm thinking of buying someones old springs if they will fit and lower my car. I don't want a stiffer ride, just a little lower for looks.
Anyone selling their old sport springs (if they lower my car)? I checked the Tire Rack and they sell lowering springs, not sure if they will stiffen the ride or not. Any suggestions on a soft riding lowering spring?
Thanks!!
Dave
Old 05-05-2008, 08:05 PM
  #790
e1000's Avatar
a quarter mile at a time
05+ sport sedan springs are much lower than the C240 springs
Old 05-05-2008, 08:12 PM
  #791
dharada's Avatar
I read some past reports and the pics were removed. I thought I read that the rears only dropped it 1/4 inch??
I think I need new springs...any recommendations on a soft riding lowering spring?
Thanks! Dave
Old 05-05-2008, 09:35 PM
  #792
venturaII's Avatar
'02 C320 Wagon
So how do you go about ordering them? There are different Sport springs depending on vehicle options...
Old 05-05-2008, 11:18 PM
  #793
e1000's Avatar
keep an eye on the classifieds section.
Old 05-06-2008, 02:25 AM
  #794
I liked the Vogtland springs when I had them.
Nice ride, not too stiff, not too low.
Just right!
But my shocks eventually wore out so I went with a CO setup and adjustable shocks. Much more expensive, but so is a comfortable pair of nice shoes you wear every day! Same thing.
If you just want lower you could cut a 1/2 a coil off....
but I don't recommend it.
Thanks!!
Dave
Old 05-06-2008, 10:56 AM
  #795
costerdock's Avatar
I'm in the same boat - c240 with 17 inch c230 '05 rims (which I think are one of the nicest looking set of OEM rims ever produced)
I've been flip flopping over the last 2 years - do I call carlab and get the Tien Stechs - they had a special installed and out the door - something like 500)
I only want the front lower - the rear looks good.
Like I say I flip flop - I see my car in front of my house - and it sits perfectly - then I'm at work and I see my car in the lot - and it looks jacked up and I cringe.
The research that I've done - I'm going with the stechs (if I ever do it.)
Old 06-05-2008, 09:25 AM
  #796
gaiex's Avatar
'08 CLK320CDI AMG// '13 E500 Coupe AMG// '17 E350d AMG
I have a question for you guys,
I dropped my car some time ago, with eibach pro-kit springs, but I noticed I have different heights at the front, 65cm left 64cm rigth!!!
What could cause this!? Maybe alignment?
I have a special alignment done withe MB alignment screws (one wheel pushed to the front, etc... since my tires where worn outside since the car was new!)
Happened to someone else?!
Old 06-06-2008, 08:38 AM
  #797
gaiex's Avatar
No reply!!!
Old 06-06-2008, 02:42 PM
  #798
Blake P's Avatar
'09 A4 S Line
Originally Posted by gaiex
No reply!!!
I guess that means it hasn't happened to anyone else.
Old 06-06-2008, 05:15 PM
  #799
KIRA's Avatar
2002 C230 coupe , NOt THE AVATAR!!
maybe shock a bit worn out on one side?
Old 06-06-2008, 07:21 PM
  #800
anson.w203's Avatar
05 C230SS
+1 or top hat not sitting properly or strut not securely bolted into place or maybe even a slightly deflated tire?
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
Quick Reply: W203/CL203 Suspension (Shocks/Springs/Sway Bars) Discussion/Upgrade Thread
