W203/CL203 Suspension (Shocks/Springs/Sway Bars) Discussion/Upgrade Thread
#1254
2013 ML350
NegroC230, Some feel the drop/lowering in front is not enough and cut a half or full coil to lower the front a bit more. This is done with a cutting wheel by the user and is not an option from H&R. Cheers, Greg
#1255
This forum amazes me more by the day i am reporting for "duty " to acquire help and give back some advice. I am struggling with my own other post , which is highly unacceptable by Merecedes owners, yet you guys are cutting springs here, ghetto style, and that seems to be alright with Mercedes community....i need to start recording these posts, for future use...
#1256
1 Post
...a panty dropper...
#1257
and how do you go around the calculations and measurements that were performed by engineers at the factory to accommodate the travel distance of the particular vehicle? How do you know that you will not bottom out , hows the ride quality after such cut? How many perches are you guys cutting? 1/2? one full coil? thats the strangest thing done to a coil spring , right after heating it up with a torch , LOL, which i have seen people do to go around buying a set of lowering springs
#1261
1 Post
#1262
Super Moderator
sway bar bushings i would say. they seem to be a problem on the w203's. that is what caused my noise in the front end. maybe someone else can tell you more about how to diagnose it. i did not fix it myself because i didn't have the time but the bill was like 550.
#1266
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Also possibly sway links. Plus check you don't have a damaged rack bush. Grab tie rods that come out of rack boots & shake. Lie under car & get someone to turn steering back & forth while you listen.
#1268
2010 C300, 2012 Mustang
#1269
What is a professional shop for spring cutting????LOL " Professional Coil spring cutting shop"...lamest gay response i have ever heard!!!!! Its a ghetto and cheap way to lower your car, period!. Get a set of coilovers and stop cutting corners, you wont get far, i guarantee you that!!!!
OMG its Nate: Ghetto comes out of your mouth , boy. Learn to respect other members, douschebag .
#1270
1 Post
C230 coupe 2002
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
#1271
ok mr smart *** from what i read onlly the front is adjustable unlke the h & r which the rear sway is also adjustablee ..ok and i would say not to drill them out it wasnt made for them to be drilled out and with ut any doubt ur just gonna make them weaker by doin that ..any one have anything to say now ..dumbass
#1272
MBworld Guru
white and whiter
ok mr smart *** from what i read onlly the front is adjustable unlke the h & r which the rear sway is also adjustablee ..ok and i would say not to drill them out it wasnt made for them to be drilled out and with ut any doubt ur just gonna make them weaker by doin that ..any one have anything to say now ..dumbass![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
![](http://forum.e46fanatics.com/images/smilies/facepalmsmiley.gif)
1. he's asking about the front bar. you think I don't know the H&R rear 19mm bar are adjustable?
2. If you had actually visited Eibach in Corona, CA. you would know the holes are drilled after the bars are bent to spec with the ends flattened to allow the place to drill the holes. making the 10mm hole larger to 12mm doesn't make any structural difference.
#1274
06 C230 6 Speed FTW
#1275
Moped
!!!!!!!!! who wants to help me adjust my c/o before i get my alignment done??? !!!!!!!!!!
also im getting vibrations after swapping to c/o.. weird.. i dont think its the spacers since they are H&R hubcentric..
