condisation in my headlight?
Old Apr 1, 2005 | 08:01 AM
ernster's Avatar
2016 E63s AMG
I have the bi zenon and there is condisation in the glass. How do i get rid of that. Will it evaperate? It was there all day yeasterday, and last night. I hope it is gone by this afternoon. Will warmer temps make this go alway or do i have to bring it in.
Old Apr 1, 2005 | 08:37 AM
MB-BOB's Avatar
Admin Alumni
See Garage
I don't know about the moving, self-levelling bits in the BI-X, but my Halogens are sealed units, so I've not had any condensation in 4 years, and have not seen this on any other MB in memory... I would take it in.
Old Apr 1, 2005 | 12:13 PM
CitronC230K_03's Avatar
2003 Citron Green C230KMT
my passenger side BiX had condenstation in it. the autoleveling motor went out and the unit had to be replaced.
Old Apr 2, 2005 | 02:47 AM
Moviela's Avatar
I had condensation in both my foglights, MB USA picked up the tab.
Old Apr 2, 2005 | 12:26 PM
Burnt Toast's Avatar
if you have condensation IN the light, you should have MB look at it. your light must not be sealed all the way. most of the time its just the glue that holds the front cover to the backing.
I remeber back when i was a VW owner. a lot of people would take off there headlamps, stick them in the oven and bake them for a few min, then pull them out and pull apart the front cover. then they would paint the inside black, reheat, and replace. many many people who did not put the cover on right got condensation in side the light.
Old Apr 3, 2005 | 02:39 PM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
very unlikely...the sealant used to glue the lenses into the automotive lights is not known to be leaking in anyway.
Headlights by themselves do fog up every now and then depending on the temoerature (changes) outside and the humidity...with frosed lenses this is not vissible...with clear glass lenses it is.
If the headlight has condensation every once in a very long while - there is nothing to worry about...take the cover of the rear of the headlight and leave the headlights on for an hour of 2...
greetingz,
Old Apr 5, 2005 | 08:10 PM
lars's Avatar
05 CLK 500 cab
I'd follow Bob's advice and take it in. Some makes seem worse than others for this problem. I remember being shocked by its frequency on a Nissan new car lot earlier this year. Whatever, if you see drops on the inside of the glass or persistent fog, it's probably a manufacturing problem.
Old Apr 5, 2005 | 08:19 PM
mypantsaretorn's Avatar
2002 c320 wagon
i actually had the same problem in my bixenons..but it was during a very big storm..and its been fine ever since...
Old Apr 5, 2005 | 11:45 PM
elchinocache's Avatar
c240
do what mbenznl suggested sounds like a good plan.
