Squeaky Suspension
Old May 12, 2005 | 11:32 AM
Willy203's Avatar
Squeaky Suspension
Does anyone ever had problems with squeaky suspension, especially the front one ?
If yes, what did you or your dealer do to fix that ?
Thanks, it is driving me crazy.
Old May 12, 2005 | 12:58 PM
Narcissus's Avatar
2001 C240 Tectite
Depends what year your car is, 2001-02 had weaker fromt arms that are known to fail. Had this fixed by my dealer last year. Could also be bushings...
203-330-39-11 Thrust Arms 255.90$
203-330-40-11 Thrust Arms. 255.90$
203-333-02-14 Bearing Nut 53.20$
203-330-33-11 Thrust Arm 311.40$
203-330-34-11 Thrust Arm 311.40$
000-330-00-18 Pin 77.68$
000000-003281 Nuts 6.44$
Old May 12, 2005 | 02:47 PM
MB-BOB's Avatar
Admin Alumni
See Garage
Squeaks especially upon entering curb cuts for driveways, etc. as the unibody flexes. My C320 is now 4 years old, and had "dry" bushings in the front sway bar and tie rod ends. I just had mine replaced under warranty. There apparently is a service advisory out on these and MB is backed up in providing the replacement parts due to the demand.
The only question I have is whether they are replacing these with newer parts of the same design, or parts of improved composition so the squeaks won't return.
Old May 12, 2005 | 02:54 PM
Narcissus's Avatar
2001 C240 Tectite
SA said they were new part, mechanic said it's the same crap
who know
Old May 12, 2005 | 02:59 PM
Saprissa's Avatar
From: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
just lay off the French Fries !!
Old May 12, 2005 | 10:09 PM
Capt Nemo o2's Avatar
'05 C230SS 6MT, 1966 Triumph TR4a IRS, Shelby Cobra 427 Supercharged
No! Keep eating the fries, but instead of using a napkin, wipe your fingers on the suspension bushings! The squeak might just go away!
Old May 12, 2005 | 10:16 PM
Saprissa's Avatar
good advice !!
Originally Posted by me @ McDonald's
make it a SUPER-SIZE please ! Need to lubricate my bushings
Old May 13, 2005 | 05:18 AM
Willy203's Avatar
Hahahaha....thanks for all advices.
I appreciate them.
Old May 13, 2005 | 10:51 AM
mattjg's Avatar
same problem here
i had the same problem on my '01 c320 , noisy front end , the dealer is replacing the thrush rod [backordered] under warranty
Old May 13, 2005 | 03:07 PM
punju112's Avatar
Anyone know how much replaceing the bushings would be? I have the same problem, though it comes and goes.
Old Feb 13, 2007 | 11:41 AM
WaveyKat's Avatar
Something Slow
you can buy the bushing and have them pressed in they cost like 25-30 each for the lower and upper control arms you can also replace the sway bar bushings while you at it. also check your tie rods inner and outer links
Old Feb 13, 2007 | 04:28 PM
dalazernet's Avatar
2020 GLC300 4MATIC
Well for what its worth, my car since just about day one has had a rather noisy suspension. I hear it on occasion when turning into driveways... but more often when I step on the gas pedal at a light. The car starts moving and as the body shifts I hear an "ERRRRRRR" from somewhere. I just turn the music up and keep on driving...
I suppose on my next service (Service B which is apparently due in 900 miles, so nags my car) I might mention it to them and see if they have any thoughts. Although, I'm pretty sure this isn't a consistent problem -- usually after it has been wet outside, etc. Reminds me of my old Grand AM GT... so I don't mind it much.
- Eric
