My AC Suks!
My previous 1997 Golf ($15000) and 2000 Mazda Tribute had better AC than this 2005 MB C230k
performance wise, i didn't notice any major loss from driving for a couple hours with the A/C on, i don't know what these clowns are talking about heat soak and huge HP losses...
anyway. should I call the service department to see if they can make it ice cold??
anyone else with an 05' C230 notice the A/C is not ice cold??
I never use the AUTO function and I can't keep the AC on 68 the whole time, just like "nukblazi" said. Gets too damn cold.
If not, both of you should take it to the dealer (since your cars are still under warranty) because just to give you an example of how cold it should get, I was in Las Vegas last weekend in 100+ degree weather and it felt cooler in my car than it did in some of the casinos.
I wonder what how different the AC reacts to the digital vs. analog setup or if it has any affect at all?
My 02s Ac is super cold. I could make snowcones and freeze my ***** off all at the same time!
hahahaha
makes me wish i had heated seats !!!
I have have had 4-5 W203's since 2001 and none had a powerful AC system. The worst was my C32 wich would NEVER get cool on a 100+ degree day here in Southern Californa. I just dont think the compressors are strong enough in our cars.
sorry
Here is a basic primer on automotive AC: http://www.familycar.com/Classroom/ac1.htm
Some interesting checks to make on your car is to put a small thermometer in the vent. You should read less than 40 F. The compressor inlet pressure is near the actual temperature in the evaporator. 30F will be 26.1 psig for 134a, 35F will be 30.4, and 40F will be 34.1 psig. If your pressure is higher, the temperature in your car will be higher. There is no difference between analog or digital controls in respect to how the compressor circulates the 134a.
Some tips to get cool faster....
When you first open the car, open all windows and sunroof and run fan on high to expel hot air from the cabin. One to two minutes is enough.
Close the windows, and set the system to recirculate to cool only the air in the cabin. A low to medium speed blower will reduce cabin temperature faster. Setting the temperature control lower will not cool the car faster.
When the temperature is comfortable, you can turn recirculate off. This will open a door to the outside air. The blower will then draw this air over the evaporator and cool it. If the car becomes too hot, lower the blower speed, so the air has more time in contact with the evaporator to cool it.
Examine hoses and fittings in the ac system. Any stain or oil on a fitting or hose should be investigated as a possible leak. If the system is opened for any reason, make sure it is evacuated for at least 45 minutes, and leak tested before adding 134a. This is to boil off any moisture in the system.
Whoa!!!
Did you goto college for that? Just playing....Thx alot for the info.
