Electric antenna output for Ipod
Does anyone know where can I get a DC output coming from the Audio20, I need it in trunk box to connect my Ipod.
Can I connect it directly with an adapter 12-9 Volt DC, or Ampere aren't enough, and I need a relais?
What I mean is that when you switch on the Audio20 you should have the DC power, and when you stop it the DC should be interrupted too.
If you're looking for a 12vdc output in the hatch area of a sportscoupe, remove the first aid kit panel, locate the fuse block and look at fuse #7.
Audio 20 does not have a power antenna output....the car does not use a power antenna.
Why the heck would you want your iPod in the trunk where you can't control it?
What the heck are you REALLY trying to do?
What I'm searching is a 12vdc output, active ONLY when the Audio20 is powered, switched on, turned on.
When I remove the key from the car, the Audio20 stops to work, I wish that Ipod did the same.
Is that clear enough?
Is the Icelink the same "Ipod integration kit" "Ipod interface kit" B67824213 object of another thread here?
My question is: what happens when you stop the Audio20, does Ipod switch off too, or does it continue playing (and you have to stop it manually)?
Indeed I want to put it in the compartment under the armrest, not in the back trunk.
