Swapping Hood problem
Old Jul 22, 2005 | 04:46 PM
Cappa26's Avatar
A box on 4 wheels
There are a total of 6 screw, 3 on each side that hold the overall hood up that are connected to the latches. Now I'm having a hard time unscrewing them and whe i press really hard it starts rubbing the grinding the shape into a circle, any ideas or suggestions?
Old Jul 22, 2005 | 04:58 PM
Saprissa's Avatar
From: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
You are gnawing the torx shape of the screw.
STOP ! if you grind them to a circle, you will NEVER get them off.
You are either using the wrong size Torx driver, or pushing too hard.
Try lubricating the screw from the opposite side.
Carlos
Saprissa@aol.com
Old Jul 22, 2005 | 05:07 PM
CitronC230K_03's Avatar
2003 Citron Green C230KMT
or strip them, and drill them out at your leisure.
Old Jul 22, 2005 | 05:27 PM
mbbodytech's Avatar
04 C320 Coupe MT
I like your line of reasoning.....I was thinking the very same thing!
Old Jul 22, 2005 | 05:35 PM
what can i say..............im a realist!
Old Jul 22, 2005 | 05:55 PM
Cappa26's Avatar
A box on 4 wheels
Strip? Explain
Old Jul 22, 2005 | 06:36 PM
Cappa26's Avatar
A box on 4 wheels
Lubricating didnt work any more suggestions? I just understood the joke -_- im so slow
Old Jul 22, 2005 | 06:39 PM
Saprissa's Avatar
no joke.
if you've already stripped the screw. Your only alternative may be what Doug said,
and drill them out. You're going to have to get new screws altogether, and recommend getting a good set of TORX drivers.
Old Jul 22, 2005 | 07:16 PM
Cappa26's Avatar
A box on 4 wheels
Didnt strip them yet, and no the screws arent messed up.
Old Jul 22, 2005 | 08:07 PM
Saprissa's Avatar
don't know what to tell ya then...
just make sure you're using the right size TORX driver.
it should fit snuggly and tight. if you're off by just one size you start stripping the inside pattern of the screw.
if, it still won't come off... might have to take it in to a body shop.
Carlos
Saprissa@aol.com
Old Jul 22, 2005 | 08:08 PM
Cappa26's Avatar
A box on 4 wheels
Thanks, im going to take it to the dealers right now and tell them to loosen it for me
