View Poll Results: How many of you have used Dyno Mode on your Car to Have some Fun (Burn Outs, Fish tai
Yes
57
46.72%
No
65
53.28%
Voters: 122. You may not vote on this poll
Dyno Mode - All you want to know
Old 03-03-2011, 09:02 PM
  #76
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Trey that is the pre-facelift procedure and will not work on the facelift cars.
Matt - you've got the procedure right, but make sure the display screen is on the odometer. It won't work unless it shows the odometer.
Old 03-03-2011, 10:22 PM
  #77
Super Moderator
samaritrey's Avatar
THE C350
i did not see what year his car was lol
Old 03-04-2011, 10:08 AM
  #78
tiderfish's Avatar
C230 Kompressor Sport
Thanks for the replies guys. I had tried just holding it. That only reset the trip odometer. I tried a couple more times after seeing the videos of others doing it. They had a more lax attitude toward getting into dyno mode. I was pressing reset so frantically I don't think the computer had a chance to register the input, so I slowed down. Once I put the key in the 1st slot, I casually pressed reset three times and got into dyno mode. Now my tires are NOT safe from my lead foot!
Thanks again!
Matt|ttaM
Old 03-04-2011, 04:49 PM
  #79
LILBENZ230's Avatar
I have the same car as you and my tires are always safe, dyno mode or not. It doesn't have the power to do anything.
Old 03-04-2011, 04:50 PM
  #80
LILBENZ230's Avatar
And just so everyone is clear on this - do not use dyno mode for the purpose of doing dough nuts! It will blow the power steering pump. Documented time and again on here.
Old 03-04-2011, 05:01 PM
  #81
Super Moderator
samaritrey's Avatar
THE C350
oh matt you are not supposed to tell them about that till they blow it
Old 09-23-2011, 08:28 PM
  #82
jtalbert's Avatar
2004 C240 4Matic
Originally Posted by SickSpeedMonte
That oil line is blank on my '07 2.5L... Is this not shown on the '06-'07?
I have a 2004 C240 4Matic and mine was blank too.
I then did the electronic oil level measure while in dyne mode, it said my oil level was okay, and then used the dyno menu and it said I had 7.4qt oil.
After starting my car, dyne mode was still up and I could see my oil level fluxuating, usually in the 6qt range, but saw it get down to 5.9 then shoot back up to around 6.4.
Old 02-06-2012, 11:53 PM
  #83
Vishal925's Avatar
2005 w211 Mercedes Benz E55
Where exactly do I use dyno mode on my e55 track? Drag race? Where?
Old 10-05-2012, 12:17 PM
  #84
Euro_Driver92's Avatar
Ive tried this procedure multiple times in my 01 c240, no luck. I cant even get the voltage display up. What gives??
Old 03-21-2013, 11:53 AM
  #85
tjk
tjk's Avatar
C250 Coupe
Hi all.
Does anyone have an idea if Dyno Mode actually affects the dyno run (power/torque) on the stand. Shoud there be a difference if dyno was done without Dyno Mode ON?
Old 03-22-2013, 07:00 PM
  #86
tiderfish's Avatar
Make sure the computer is currently showing the odometers, trip and full. Next turn off the car, remove the key, and try again.
Pop in the key, turn one click, and press the odo reset button 3-5 times fast. you will see the option to put it in dyno mode, press the + button, and with it highlighted turn off the car. Once you turn it on again it will be in dyno mode. Once it is started you will see warnings for ABS and traction control. The ABS idiot light will be illuminated on the dashboard.
I do not think it will produce any more power. At least my butt dyno does not register more power.
I usually use it during the dry summer months, so that when I launch, the brakes are not applied if I loose traction. My car is a manual, so it is easy to break traction. If I am making a left across traffic, the last thing I want is to have the brakes applied.
Old 04-05-2013, 11:44 PM
  #87
p.willy's Avatar
2003 Mercedes Benz C240
Im going to try this on my 03 c240. Hope it works so I can do some burn out s....lol
Old 04-06-2013, 04:02 PM
  #88
Super Moderator
samaritrey's Avatar
THE C350
Go for it I will start to get the PN's ready for you to fix you car when the PS pump goes.
Old 04-06-2013, 05:45 PM
  #89
p.willy's Avatar
I had no change in the ability to do a burnout. maybe because I have good tire and had alot of weightin the car....I would just use it to set the oil level and that's about it .the car is not that powerful but I love it .
Posted from Mbworld.org App for Android
Old 04-07-2013, 08:53 AM
  #90
C160's Avatar
2006 CL203 C160 Sport
What is this stuff about the PS pump giving in?
Just bought a W203 with manual gearbox, and having used a miata for the last 3 winters (great fun) I must say that not being able to fully disengage ESP in a safe matter is horrible news to me
Old 04-11-2013, 02:56 PM
  #91
C160's Avatar
So from what I have found regarding this issue so far, is that full lock on the steering seems to kill the PS pump while in dyno mode. Does this mean that as long as I stay of full lock I will be fine, or is there more to it?
We still have snow here, so if anyone knowledgeable would care to elaborate it would be much appreciated
Old 04-12-2013, 03:15 PM
  #92
Super Moderator
samaritrey's Avatar
THE C350
Well Dyno mode does not kill the pump actually it is the driver who does it by holding the wheel all the way over and that is what causes the issue. I have played with Dyno mode many times and never had an issue so don't worry about it.
Old 04-14-2013, 09:32 AM
  #93
C160's Avatar
Thank you for replying sir. We do organized trackdays on frozen lakes here in the winter, and it just doesn't work at all with just the ESP button turned off.
Old 06-22-2013, 12:26 AM
  #94
MichaelKane's Avatar
2005 C230 Kompressor
Tried Dyno Mode today, on a closed coarse! No donuts or anything
Just laid into the throttle and put down two nice long patches of rubber.
Not really what the car is made for but I had to test it at least once.
and it worked very well!
Old 03-07-2017, 06:57 PM
  #95
Rovel's Avatar
2007 E63 Amg
I own 2013 E550 4matic. Put it in dyno mode. Tried hard acceleration hoping it would spin rear tires, didn't happen
How else can I have fun in dyno mode in a 4matic car? Have anyone floored it in dyno mode on ramps and/or backroads?
Quick Reply: Dyno Mode - All you want to know
