View Poll Results: What color calipers?
Gold
15
7.18%
Red
66
31.58%
White
5
2.39%
Gunmetal
20
9.57%
Silver
60
28.71%
Black
43
20.57%
Voters: 209. You may not vote on this poll
BRAKE Pad, Rotors, & Calipers Discussion Thread (OEM, aftermarket, etc...)
Old Sep 29, 2005 | 12:11 PM
  #226
mleskovar's Avatar
'17 Jaguar XF
Originally Posted by razorfish228
I guess the OEM pads require less pressure than in the cold?
About the brake dust in the front, is it significantly less on the wheels? I have to clean my wheels everytime I go out for a few miles.
It takes only a few stops for the pads to heat up but yes it takes more pressure when cold. Just a little more, noticeable but not enough to make any changes to the way you brake. The OEM pads are smoother when coming to a complete stop, but once again, only noticeable, not an issue. I don't push my car hard but once I was in some twisties in No. Ca. pushing it hard and the Porterfields didn't even begin to fade. Very solid and no extra pressure required. They are a harder, higher working temperature pad suitable for daily comfort use. WAY less brake dust.....that's why I put them on to begin with.
Old Sep 29, 2005 | 12:31 PM
  #227
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
I guess I haven't gotten a really good guage since I installed them just due to my being conservative about "break-in period". I should be able to get a better judge by this weekend (as 150 miles is coming up close). I wouldn't be surprised if I notice how they feel when my braking style gets back to "normal".
All-in-all, I feel IMO that the Porterfields are better than OEM (combining less brake dust and stopping power).
Old Sep 29, 2005 | 02:05 PM
  #228
nlpamg's Avatar
2019 GT3 RS, 2017 M3 30 Jahre
Originally Posted by advans
PORTERFIELD has a lot less brake dust...but...stopping wise, i think the softer OEM ones are better...the Porterfield ones are a bit harder, and doesnt stop as good as the OEMS
woah, I don't like the sound of that...
I really could care less about brake dust, I'm more concerned with stopping power.
What are the other options? Anyone try any other pads?
Drex, let us know how they go... Also, how many miles do you have on yours again? I'm getting close to 19k and I'm worried that I may have to change pads soon...
Old Sep 29, 2005 | 02:11 PM
  #229
drexappeal's Avatar
Phil, these are definitely worth it. The braking power is better than OEM once heated up. It's only slightly less pressure when cold, but doesn't mean you can't stop at all.
The important thing with these is that, you have to give any "race" brakes a break-in period, otherwise there is a high risk of warping the rotors.
My mileage is at a little over 19K. Keep in mind, I live in the hills (more braking than normal) and it was only my front pads that were at around 10% when I went in for service B. The rear pads still had 35% life. I just decided to do both axles at once, so I wouldn't have to mess with them later on.
Old Sep 29, 2005 | 10:04 PM
  #230
advans's Avatar
C55 ///AMG, 535xi
I'd advise you to get AMG calipers with porterfields and drilled slotted rotars, maybe the much larger brakes and the slotted drilled rotars can havve a better stop, besides 01-03 w203s, the brakes are so damm small =T, this way, u get a cleaner look, abt the same stopps and less brake dust, but thats a higher investment, otherwise, just get the BREMBO set...if not, go back with the OEMS and think abt it next time u change brakes
Old Oct 13, 2005 | 07:04 PM
  #231
drexappeal's Avatar
Forgot to update everybody on how the Porterfield brake pads feel.
After passing the break-in period, I've been testing the braking power here and there and I definitely have to say that these pads grip very well. I don't know if I'd go so far that they grip "better" than OEM, but they are on par and maybe a little bit better.
The thing is, I still contend that when they are cold, the breaking power is slightly less than expected. It's not as significant as I thought it was (during the break-in period), but it's just enough for me to notice (i.e. a little more pressure needs to be applied when cold). It definitely won't make you have to adjust your breaking style at all (regardless of a cold or warm run).
If you take that and then also the consideration of much less brake dust, I'd give these an A- (minus is just because I was expecting a bigger jump from OEM, but it wasn't as big as I thought in terms of stopping power). I'll still take these over OEM pads, but this also tells me that the OEM pads are pretty darn good. Remember, I have the AMG front brakes (stock on my car), so I can't say it would be the same for non-AMG brakes.
Old Oct 13, 2005 | 07:39 PM
  #232
yeloaw's Avatar
c240
I just changed my pads 4 days ago. I am running on Mintex pads. So far so good, no squeaking and braking performance feels same as OEM. As for brake dust it is too soon to tell, however I have heard Mintex has very little brake dust. Mintex, Pagid, and Textar are all the same I hear.
Old Oct 13, 2005 | 08:13 PM
  #233
mleskovar's Avatar
'17 Jaguar XF
Pad break in....
Some good information on brakes at this site. Consistent with what I've read elsewhere and easy to digest. But unless you race, carry or pull heavy loads, or are able to push your car to the limits in legal driving, fancy brakes are only good for looks.
http://www.stoptech.com/technical/
Old Oct 15, 2005 | 10:45 AM
  #234
gaiex's Avatar
'13 E500 Coupe AMG// '17 E350d // '24 E53 AMG
Bad brake pads???
I'm noticing some squeeqing when I brake and the brake discs look like they are scratched and I still have plenty of pad (stock ones) to wear (only 15000miles)
Attached Thumbnails BRAKE Pad, Rotors, & Calipers Discussion Thread (OEM, aftermarket, etc...)-dsc02465.jpg   BRAKE Pad, Rotors, & Calipers Discussion Thread (OEM, aftermarket, etc...)-dsc02475.jpg
Old Oct 15, 2005 | 12:27 PM
  #235
chibial's Avatar
i think thats normal? i got 27k on my 05 c230k SS mine look just like that and have plenty of pad left also. i think the all 05 brakes had a squishly feeling to them.. i drove a 03 loaner once and the brakes felt solid.
Old Oct 15, 2005 | 12:45 PM
  #236
mleskovar's Avatar
'17 Jaguar XF
[QUOTE=gaiex]squeeqing and the brake discs look like they are scratched QUOTE]
Normal, and normal.
Old Oct 15, 2005 | 12:58 PM
  #237
MB-BOB's Avatar
Admin Alumni
See Garage
My stock Lucas pads started to squeek at half wear. Changed them out at 32,000 miles. A lot of members say this about their standard pads. So it's nothing to worry about, unless you can't stand the noise.
Old Oct 15, 2005 | 06:06 PM
  #238
jiifamily's Avatar
MBZ ML350 BlueTEC
9K Miles 05 C230K SS Brake
Mine has only 9K and the rear right brake is making noise also.
Old Oct 15, 2005 | 06:19 PM
  #239
M230K's Avatar
2012 MERCEDES CLS63 AMG
maybe if u clean the rims it wont look like u need new pads (which u dont)
Old Oct 15, 2005 | 06:57 PM
  #240
gaiex's Avatar
Its rainning a lot here, so... :p
Old Oct 15, 2005 | 08:46 PM
  #241
M230K's Avatar
lolz, still.. u should jus give it a quick rub with a cloth
hehe!
Old Oct 16, 2005 | 09:57 AM
  #242
gaiex's Avatar
hehe!
Ok, sorry, maybe next time
Old Nov 23, 2005 | 02:11 PM
  #243
edd1e22's Avatar
2005 G500
Cheapest source for porterfield brake pads?
Does anyone here know the cheapest source for porterfield brake pads? Thanks
Old Nov 23, 2005 | 02:56 PM
  #244
Buellwinkle's Avatar
Look for places that don't sell stuff for German cars and you'll be better off. I got mine from a place that sells stuff to ricers and it was about 30% cheaper than other places. It was 4 years ago so I don't remember the place but look around, you'll find something. Also consider the MB low dust pads, they work about the same for me as the Porterfields.
Old Nov 23, 2005 | 03:20 PM
  #245
drexappeal's Avatar
I agree with Buellwinkle. If the OEM low dust pads are cheaper, go with those. I can't notice that much a of stopping power difference with the Porterfields. Check with FrankW (Are you still a sponsor, Frank?) or one of these sponsors that I had mentioned to you:
https://mbworld.org/forums/adindex.php
Old Nov 23, 2005 | 05:16 PM
  #246
edd1e22's Avatar
2005 G500
I emailed frank and he never got back to me so I assume he's out of the business? Anyone else?
Old Nov 23, 2005 | 08:31 PM
  #247
razorfish228's Avatar
BLACK 05 C230SS
I'm also looking, so if anyone knows please post back or PM me.
Thanks!
Old Nov 23, 2005 | 08:45 PM
  #248
mleskovar's Avatar
'17 Jaguar XF
Low Dust Pads...
Haven't heard of these. What's the trade off? Any part number or description reference?
Old Nov 24, 2005 | 03:18 AM
  #249
rubensans's Avatar
Brabus K3
I have MB "low dust" and the produce a lot of dust !!!
I have the C32 brake setup on front.
I also want to swap to portfields.
Best Regards.
Old Nov 24, 2005 | 04:20 AM
  #250
genesis471's Avatar
'06 C230 SS Black on Black
I have always bought direct! I have not been able to get them cheaper then direct.
http://www.porterfield-brakes.com/pads.html
Mike
You have already rated this thread Rating: Thread Rating: 9 votes, 5.00 average.
