Official S-Class/W220 Style Taillights Thread
Old Jun 24, 2005 | 06:23 PM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
the 2005 models come with a 7pin taillight connector...the pre 2005s have a 6pin taillight connector...these aftermarket LED taillights are manufactured for the pre 2005s.
greetingz,
Old Jun 24, 2005 | 06:32 PM
MBenzNL's Avatar
some slow@$$diesels
on the 2005s the car uses both bottom bulbs for illumination...on the pre 2005s it only uses the outer bulb for illumination (although I think I saw some pre 03s that used 2 bulbs for illumination per side as well).
The fact that one side has one wire less is because that side does not have a foglight bulb wired up.
The rear SAM can be programmed through stardiagnose to either support 1 taillight bulb per side or 2 taillight bulbs per side so by going for 1 bulb the car might come up with a malfunction code (unless you change the rear SAM setting).
The last thing you want to do is soldering anything onto the car's wiring harness...just get the pre 05 taillight connectors (mailed you the partnumbers) and the proper tool to take the pins out of the connector so you can swap them.
greetingz,
Old Jun 24, 2005 | 07:01 PM
360_iti's Avatar
W203, W211, W219, W212
Steve, so are u saying that those lights are a perfect fit to my C32 since it's pre-2005 ?
EKY I'll buy them from u if u're selling.
Old Jun 24, 2005 | 07:12 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
I thought that "altezza" meant those funky looking round ones with the rest being some reflective surface. Do I need to revert back and study up on my ?
Old Jun 24, 2005 | 08:08 PM
MBenzNL's Avatar
some slow@$$diesels
those are a perfect fit for any 203 (as far as aftermarket parts can be perfect fit)...for the 2005s one just needs to change the connectors (using original MB parts)...that is how we do the 2005 taillight upgrade for the pre 2005s as well - by changing the connector.
greetingz,
Old Jun 24, 2005 | 08:13 PM
Jim Banville's Avatar
'06 Lexus GS300 RWD, '07 Camry SE V6 auto, '91 190E 2.6 auto
Can the LED lights be fitted into the OEM housing?
Old Jun 24, 2005 | 08:16 PM
  #32
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
How good are you with a dremel? :p
Old Jun 24, 2005 | 09:29 PM
  #33
ctC230K's Avatar
excites your girlfriend
lol those tails look nice, like an S class with LEDs, maybe u can just cut the connectors and hard wire it!
Old Jun 24, 2005 | 09:31 PM
  #34
ctC230K's Avatar
i thought altezza's were only for riiiiceee
Old Jun 24, 2005 | 09:49 PM
  #35
I was hoping the LED "pod" could be transplanted into the OEM housing. Is it molded into the replacement housing?
Old Jun 25, 2005 | 01:02 AM
  #36
MJ50's Avatar
Super Moderator
bone stock E55 AMG
u can get 'em on eBay...
Old Jun 25, 2005 | 02:22 AM
  #37
W0n6_3d4n's Avatar
C200K (w204)
How much brighter do u think that LED compare to E class one?? Off topic (still about LED), can someone help me with regard to 3rd brake light malfunction, I've this error for god know how long, stealer fix it and last for 1 week, always coming back, sometimes it work sometimes it doesn't, work mostly in summer, in winter it just throw malfunction error. Stealer suggest changing the entire cluster, which cost a bit steep in here. Any idea wat happen??
Old Jun 25, 2005 | 05:09 AM
  #38
TheBossman's Avatar
04 C230K-ss
Thats just a steriotype with a 'broad' range of what that falls into for untasteful mods to cars I guess
Old Jun 25, 2005 | 05:16 AM
  #39
M_M's Avatar
M_M
C32 AMG
looks ugly IMO. Mini S-class?
Old Jun 25, 2005 | 08:01 AM
  #40
EKY's Avatar
EKY
2006 Acura RL - Aspec rims/spoiler, JDM grille
Originally Posted by crazi55
I got those lights too. The LEDs do act as a running light along with the running light on the bottom of the taillight.
Since you're in Hawaii as well.. I wouldn't mind meeting up with you to check out your tail lights if you don't mind. I'm going to order the mercedes 6-pin connectors from the pre '05 w203's as steve mentioned above and make it work.
Does the car look funny with the top brake portion always on as a running light? Any pics? I wonder if there's a way to disable the top portion from being a running light.
Old Jun 27, 2005 | 02:17 AM
  #41
benzo-boi's Avatar
2008 C300 Sport Sedan: Panarama Roof, P2, Multimedia
I saw them on ebay:
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
and wanted to see if anyone owns a pair of these. It says that it's only for 00-03, and I was wondering if it would fit '05.
I've also seen the LED ones posted in Eky's thread. His LEDs don't fit the '05, but I'm hoping someone has the none LEDs so that they can tell me if it works with the 05's 7 pin. It's nice, it really gives the car the CL look.
Attached Thumbnails Official S-Class/W220 Style Taillights Thread-ledtail.jpg
Old Jun 28, 2005 | 05:51 PM
  #42
MadC32's Avatar
C 32 AMG (203.065)
those look really nice.. Anyone know how well they fit and if they're good quality?
Old Jun 28, 2005 | 07:03 PM
  #43
360_iti's Avatar
Thats what C is called .. Baby S
Old Jun 28, 2005 | 10:16 PM
  #44
MJ50's Avatar
Super Moderator
bone stock E55 AMG
go to the other forum and u'll find more info on LED tails...
Old Jun 29, 2005 | 03:29 PM
  #45
MadC32's Avatar
C 32 AMG (203.065)
Originally Posted by benzo-boi
I saw them on ebay:
couldnt find the LED one on ebay. Can you tell me where you found those?
Old Jun 29, 2005 | 03:50 PM
  #46
TheBossman's Avatar
04 C230K-ss
So since I have an 04 and it says that these are made for '00-'03, will these fit my 04? I have no idea if my 04 has the 6 pin connectors either. I really want these just want to make sure that they would and will fit an 04 with a 6 pin also. TIA guys
-Geoff
Old Jun 29, 2005 | 04:21 PM
  #47
MJ50's Avatar
Super Moderator
bone stock E55 AMG
currently there is none on sale...
send msg to eBay user ID 175535...
or stay tuned in the 'other' forum...
Old Jun 29, 2005 | 04:32 PM
  #48
Justinius7's Avatar
greetingz,
Can stardiagnose, make both left and right rear fog lights come on? or is this a left side or right side only set up?
Old Jun 29, 2005 | 04:52 PM
  #49
MadC32's Avatar
C 32 AMG (203.065)
alright, thanks man
Old Jun 29, 2005 | 09:12 PM
  #50
MJ50's Avatar
Super Moderator
bone stock E55 AMG
i've seen LED tails for E46 by same manufacturer...
it wasn't even close to stock...
not sure on brightness of W203 LED tails, but i know you can modify with larger/brighter LEDs...
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
