c230k 6 speed not going into reverse
Old Sep 25, 2005 | 08:56 AM
kazooguy's Avatar
Please tell me it's not the tranny! '02 c230k 6 speed 60k miles will not go into reverse unless the car is rolling. What I need to do now is place the trans. in reverse while rolling just before parking. The car needs to be rolling either forwards, or backwards, with the clutch in, to get it in reverse, then it works fine. All forward gears are perfect. I changed the trans. fluid and it did not help.
Thankyou in advance for any replies.
Old Sep 25, 2005 | 11:37 AM
advans's Avatar
C55 ///AMG, 535xi
my friend had the same problem with his C320 6 speed, he replaced the tranny
Old Sep 25, 2005 | 11:48 AM
Capt Nemo o2's Avatar
'05 C230SS 6MT, 1966 Triumph TR4a IRS, Shelby Cobra 427 Supercharged
Does it grind when you try to put it in to reverse? If so, it might be the syncros. Try putting it into first and then reverse with the clutch in the whole time. But obviously something is wrong and get it checked out by the dealer. From what I understand, because most MB dealers sell so little manual cars they dont really know the transmission that well and will just replace it if something is wrong (besides little minor things). If you do have to replace the tranny, try and talk them into giving you the updated transmission from '05+ with the solid rod shifter instead of the cable shifter.
Old Sep 25, 2005 | 01:46 PM
Kenzmbz's Avatar
unless he was extended warranty he is focked. Excuse my french. 60k miles = out of pocket cost. New tranny = headache. Good lcuk buddy. I hate car problems.
Old Sep 25, 2005 | 02:13 PM
Well if he needs a new tranny whats he going to do? Live with it the way it is? Sell it? I dont think he's going to have much luck finding a used/rebuilt MB manual tranny if it comes down to him needing one.
Old Sep 25, 2005 | 02:57 PM
integlikewhoa's Avatar
Im not so sure on that very trans but most trannys dont have syncros for reverse gear. Its usally the slider or fork that has a problem. If a clutch is not fully releasing that can cause this problem too. Forward have syncros so if the clutch is not fully released then the syncros will stop the shafts from spining. So makes since reverse will show the problem first. Either way sounds like the trans will have to be removed and inspect clutch then go into tranny if needed. Peadl feels fine right? Plenty of hydrolic fluid in master cylinder? I see alot more clutchs go out then trannys but there always a possiblity. Good luck.
Old Sep 25, 2005 | 04:33 PM
Outland's Avatar
2002 C230 Coupe(M111)
I agree. This sounds more like a clutch problem than a tranny problem. Sounds like one or more of the fingers are broken or weak.
Removing the trans and bell housing is pretty easy on a RWD car....get at it.
Old Sep 26, 2005 | 02:40 AM
I agree as a possible problem. Pull trans and inspect clutch if no problem found continue into trans.
Family owns trans shop and have worked there several years. Its easier if you watch someone else do it. So i agree " GET AT IT " We will supervise from the board. LOL
Old Sep 26, 2005 | 05:25 PM
kazooguy's Avatar
Thanx for the input. a good frind of mine owns a jaguar shop, and lets me use the lift. I just used it to change the tranny fluid, and he let me borrow the vw drain plug wrench, and smaller hex fill plug tool. I didn't look like removing the tranny would be a big deal. The problem is having it rebuilt, or finding a rebuilt one. anyone have any suggestions?
Old Sep 26, 2005 | 06:06 PM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
In the meantime, did you try holding the clutch pedal down and putting the tranny in first, then reverse right away, in one motion? I do not remember whether my tranny had a problem going into reverse when it was new, but I routinely do that and never had any trouble.
Old Sep 26, 2005 | 10:00 PM
Outland's Avatar
Dood, are you listening? Its likely NOT the tranny. Its the CLUTCH. If the clutch is fine, you can burn the tranny bridge when you come to it. Just replace the clutch and get it over with. Even if the tranny ultimately is the problem, the clutch should still be replaced with 60K of hard driving on it anyway.
Old Sep 26, 2005 | 11:28 PM
Agreed but i would look at it and then make the decision of replaceing it or not. I see clutchs at work go out at 30k and some make it 150k it depends on the driver. If you are hard on it or drive a stick like a lil girl then probley going to have to change it anyways or it should be while the trannys out. Save time and money in the future.
Old May 15, 2012 | 12:13 AM
oggie1821's Avatar
2005 C230 Kompressor
Clutch Pedal Broke
I was told today my clutch pedal broke on my 2005 C230 Kompressor.. Does anyone know if it is an easy fix? I was told it broke at the pivot point where there is a pin that holds it together? Also was told the part is plastic? Is there anyone that has had this problem and if so, is fixing it easy? THANKS
Old May 15, 2012 | 09:20 AM
ncmudbug's Avatar
2005 C230K, 2019 Honda CR-V, '74 Lotus Europa
Yikes! What kind of hard driving are you doing that you need to replace the clutch after 60K miles!!!
Old May 15, 2012 | 02:06 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
No not the clutch, the mounting point of the pedal. I get it.
You need to get the diagrams off the epc.
http://epc.startekinfo.com/
Accounts are free for US.
Old May 15, 2012 | 07:32 PM
Al93's Avatar
'04 C230K 6spd
I have the 04 C230K 6spd sedan and I've got the exact same problem, but in my case it doesnt work only when I have just started the car... But if I put in any gear and then put reverse it works... Try doing this and let me know if it works... It's been like this since I bought it so I think it's a manufacturing mistake rather than something that we dis wrong..
Old May 15, 2012 | 08:15 PM
Milkm4n's Avatar
2006 c230
70k of abuse everyday and my clutch feels like it has 65% or more I would be surprised if I don't make it to 120-130k
On a side note I know a few people with jdm cars 350z sti rsx etc etc and 60-70k is normal life expectancy for a clutch
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
