Supercharger or Turbo
Old Nov 3, 2005 | 11:35 PM
m-benzw203's Avatar
01' C320
question what would be better for my c320 a super or turbo and what is the performance difference im thinking on getting one, but i want one that will benefit me. oooooooo i never heard of turbo benz if i go with a super is it better to get it from benz it self or a another place
Old Nov 3, 2005 | 11:51 PM
CitronC230K_03's Avatar
2003 Citron Green C230KMT
ever heard of a SL65 Bi-turbo or CL65 Bi-turbo?
Old Nov 4, 2005 | 12:20 AM
m-benzw203's Avatar
01' C320
no whatz up with that
Old Nov 4, 2005 | 12:23 AM
Trekman's Avatar
Silver 2002 C32, Silver 2006 CLK 350
Amg
Old Nov 4, 2005 | 12:27 AM
welcome!
http://www.mbusa.com/brand/models/CL65.jsp
Old Nov 4, 2005 | 12:30 AM
respdoc's Avatar
CLS
quite a few have done the Pratt & Whitney conversion with positive results.
Old Nov 4, 2005 | 12:40 AM
NY C32's Avatar
2020 BMW X3M Comp
MB has done turbo diesel too
Old Nov 4, 2005 | 01:17 AM
DiamondK's Avatar
'05 Diamond Black C230K
MB is also showing an SLK320 CDI Tri-Turbo show car with Alubeam paint. Pretty nifty. It's in the latest Automobile Mag.
Old Nov 4, 2005 | 01:24 AM
DiamondK's Avatar
Read about.com to learn the difference between a supercharger and a turbocharger. Neither one is inherently more powerful.
MB is not going to sell you a supercharger kit (or a turbocharger kit). You'll need to get it from a tuner.
Although, and maybe MBenzNL or someone knows the answer to this...could you order kompressor parts from a C32 and fit them onto a C320 engine? Even if it were possible something tells me it might be cheaper to go with a tuner kit.
Old Nov 4, 2005 | 01:25 AM
pookie's Avatar
2013 c300 4matic, 2002 c240
too bad it will not hit US shores anytime soon. :[
Old Nov 4, 2005 | 01:31 AM
true. i've owned two of them.
C123 300CD and W124 300D. :Y
strong engines.
Old Nov 4, 2005 | 02:30 AM
m-benzw203's Avatar
01' C320
which one is better
Old Nov 4, 2005 | 02:57 AM
pshek's Avatar
2003 C-Class Sportcoupe
It won't work. The NA C320 engine and C32 AMG engine are different. They may share the same engine block, but components such as crankshaft and pistons were reinforced on the AMG handbuilt engine. Compression ratios and timing is different. Only alternative to "super" the NA C320 engine would be to add an aftermarket supercharger from Kleeman, Renntech, or Carlsson. Be prepared to spend at least $12K-15K on supercharging it and your warranty will most likely be voided. Easier to do motor swap. Easiest method would be to just buy an AMG car.
Old Nov 4, 2005 | 06:07 AM
benzmodz's Avatar
W203 slightly modified
Complete engines go for less than tuner kits. Why a spanner set makes me more qualified than Doctorates in Engineering is anyones guess. But cubic inches beats higher compression which is why AMG feels the need to have more cubic inches as a statement in the marketplace.
If someone could do it for less money with a smaller motor .... they surely would.
Old Nov 4, 2005 | 08:17 AM
mikefl52's Avatar
2002 C230K Coupe & 2005 C230 SS
This is always my thought when I hear about people wanting to push the power outpout on standard engines that are built for a certain power output. Sure I believe that the engines including full drive train might be able to deal with small gains in power output, but something has to give up eventually downstream if you keep increasing power at the top end and don't change all components withing the engine and drivetrain.
Old Nov 4, 2005 | 11:32 AM
JDUBYA's Avatar
Turbo hands down. Don't beleive the hype about a turbo car not being reliable. It's all about the tuning.
Old Nov 4, 2005 | 12:01 PM
Justinius7's Avatar
just run with a 50-shot of wet NOS its not soo much that you will destroy anything. and much cheaper then a 10k+ conversion.
Old Nov 4, 2005 | 12:49 PM
Sauceboy01's Avatar
Blimp
Honestly guys, if the guy has the money, let him purchase the Supercharger kit from Kleeman etc.. If he doesn't then he's out of luck.
Also you guys worry about the waranty issue a little to excessively. By law the factory cannot void your waranty if you were to add a supercharger. The only way they can void a waranty or to be more accurate "WARANTY SERVICE" is if your added performance part actually caused the the waranty repair issue, and they have to prove it. Plain and simple
now, it's friday and i've typed way to much..
Liquor before beer, you're all in the clear! remember that and you'll have a great weekend! Have a happy one!
Old Nov 4, 2005 | 02:21 PM
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
...oooooooo i never heard of turbo benz ...
I'm pretty sure the SL600 is Turbo charged. Also, there was a 230 Coupe that had a custom Turbo (although I heard there were problems with the car).
Old Nov 4, 2005 | 02:50 PM
nlpamg's Avatar
2019 GT3 RS, 2017 M3 30 Jahre
Honestly, if this guy had a C230 instead of the C320, I would have called him out as being C230_617.
Perhaps he's just saying he has a C320, but I don't know... His posts have just been waaaaay too similar to our buddy C230_617.
Old Nov 4, 2005 | 03:13 PM
drexappeal's Avatar
I'd jump on this too, Phil, but not enough new threads yet. Once the "duplicate" threads and redundant threads start to pop up, it'll become more in line with C230_617.
Old Nov 4, 2005 | 03:16 PM
360_iti's Avatar
W203, W211, W219, W212
all the 600s have biturbo. s600, cl600, sl600.
again, welcome aboard m-benzw203
Old Nov 4, 2005 | 03:17 PM
AdamVax's Avatar
05' C230 Kompressor SS Mars Red 6speed--1990 300D 5speed
i believe supercharged is better because turbos lag after awhile
Old Nov 4, 2005 | 07:33 PM
Outland's Avatar
2002 C230 Coupe(M111)
It won't work.
It will work just fine. You'll need more than just the lysholm, but it would deffinately work without cracking the motor open.
Old Nov 4, 2005 | 07:35 PM
Outland's Avatar
I agree, but then again some of the replies have been at about the same level.
