spark plug
Old Nov 27, 2005 | 12:17 PM
erock841's Avatar
spark plug
I just found out about these... i searched the forum and didn't find anything so i thought i would pass it on. www.e3sparkplugs.com They supposedly improve fuel economy and power. Every little bit helps... Let me know what you guys think. I might get them to see if there is any difference.
Old Nov 27, 2005 | 07:31 PM
mleskovar's Avatar
'17 Jaguar XF
Not quite snake oil...
...but close. I do not believe any of their claims and they don't back them up with research, just more claims. Their claim to fame seems to be a new algorithm for testing. I would be VERY worried about matching the recommended heat range with a basically untried product.
Old Nov 27, 2005 | 07:34 PM
rrpnow's Avatar
2006 C230 SS
its like that turbine exhaust... "Gives you more HP and better fuel economy"... it does neither... another gimmic
Old Nov 27, 2005 | 07:59 PM
Bing's Avatar
C320 Sport Sedan 4MATIC, Cayenne S, Bayliner Capri V8, Subaru STi
I used that e3 spark plugs in my lawn mower (front wheel drive) and my weed whacker
3-5 mins use in my lawn mower, I returned it in the package and returned it at Lowe's.
It's a POS
Old Nov 28, 2005 | 04:15 PM
erock841's Avatar
well, if these e3 plugs aren't any good then do you guys have any recommendations for me? What is out there that is the best performance wise?
Old Mar 8, 2011 | 07:46 PM
KendoBoo's Avatar
S600 '03, S600 '04, C320 '02 Wagon
Take a look at this..
http://www.youtube.com/watch?v=62Kav...eature=related
The others can eat dirt, but knowledge is sweeter
Old Mar 8, 2011 | 08:56 PM
mleskovar's Avatar
'17 Jaguar XF
What exactly did you get from the video? It showed you some graphs and videos but what convinced you that the plug does something other than provide a spark?
Old Mar 8, 2011 | 09:09 PM
KendoBoo's Avatar
The video of the "Flame Front" is the part that caught my attention. Having worked in the motor industry, I understand the meaning behind how a clean burn can increase engine power and lower emissions. Low emissions show a complete burn.
That is before the cat, after the cat means sqwat..
Even with a Dyno, you only get graphs.
Old Mar 8, 2011 | 11:57 PM
mskembo's Avatar
2010 Mercedes-Benz E350
The mullet has spoken, and I can't remember what I was thinking... I'm so cold right now.
Old Mar 9, 2011 | 03:52 AM
phister's Avatar
06 C230 SS 6spd
But what plug are they comparing it to? Is it an iridium plug or a standard plug? I'd like to see comparison between our factory platinum/iridium Bosch plugs to these.
Old Mar 9, 2011 | 06:21 AM
billbillw's Avatar
2001 E55 AMG (sold)
How a plug performs in a lab means nothing of how it performs on a real car over the span of 30-50K miles. I think a major complaint of the E3 is their short life. I'll stick with tried and true technology. Plat or Iridium; Bosch or NGK.
Old Mar 9, 2011 | 07:49 AM
Glyn M Ruck's Avatar
Super Moderator
Fit the OE Bosch or NGK plugs. Good for 100K if operated in the self cleaning range often enough.
The rest is all BS.
Old Mar 9, 2011 | 01:40 PM
e1000's Avatar
a quarter mile at a time
The rest is all BS.
Old Mar 14, 2011 | 09:46 PM
efzauner's Avatar
2005 C240 2011 R350
if this plug improves fuel consuption and power by just 1pct...basically for free.. don't you think the car companies would put it in every car!
Old Mar 15, 2011 | 09:08 AM
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
There are some good aftermarket products that haven't been adapted by mainstream auto manufactures. However, spark plug is not one of those. There is really no compelling reason to go with any plug other than OEM Bosch/NGK (as suggested by other members above).
Old Mar 15, 2011 | 09:16 AM
johnand's Avatar
Super Moderator
2007 C230SS; 2014 ML350 BT
The rest is all BS.
+100000000000000000000000000000
Old Mar 15, 2011 | 09:31 AM
efzauner's Avatar
2005 C240 2011 R350
I do realize that there are many wild claims by aftermarket suppliers that use a lot of hype to convince ignorant consumers. I am sure that there are some very good technologies that do improve economy and power that need to be investigated for feasability in mass auto market (cost, reliability, manufacturability etc). I doubt that if something works and is low cost that the auto manufacturers would not jump on it.
I am an electrical engineer and I regularly see bul**** claims in high end audio. I suspect that if I was knowledgeable in the physics of combustion I would also see lots of bull**** claims in the aftermarked performance/fuel efficiency market also. Most consumers are completely unable to judge the validity of so many of these wild claims (weight loss informamercials and all sorts of other miracle cures come to mind) and are duped.
If its too good to be true.. its too good to be true.
Now if we all simply prefered smaller, lighter cars with smaller engines we could save lots of gas.... but we like our sport/performance cars! Hard for us to change our ways!
have a great day
Old Mar 16, 2011 | 06:25 PM
larimer's Avatar
2006 c230 mars red 2010 GLK 2007 Porsche C2S all gone 2007 CLK550 current
I've seen what look like conflicting opinions on using anti-seize compound on spark plug install. What is recommended?
Old Mar 16, 2011 | 08:13 PM
mleskovar's Avatar
'17 Jaguar XF
Some plugs, like OEM, have a micro coating that is an effective anti seize. They are designed for "one time use" which means the coating is gone once you remove it. I sparingly use a ceramic based anti seize even with coated plugs.
Old Mar 17, 2011 | 03:50 AM
carbonfiberwhor's Avatar
2006 C230, 2006 BMW M3, bye bye C55:(
About to do my sparkplugs, whats a good plug to order from Bosch?
Old Mar 17, 2011 | 05:09 AM
phister's Avatar
06 C230 SS 6spd
the factory platinum ones...
http://www.rmeuropean.com/Part-Numbe..._94E6B777.aspx
Old Mar 20, 2011 | 02:21 AM
Boom vang's Avatar
2019 C300 Wagon; '75 Triumph TR6; previous: 2004 C230 6spd sold after 17 years of driving
Originally Posted by phister
Although they are slightly cheaper than at the dealer $10.35 vs $16.00 their shipping costs will make the purchase moot as they charge $25 to ship to my place in Sarasota. Doesn't seem to be an alternative to overnight rush on the site
Old Mar 20, 2011 | 06:36 AM
Silver C's Avatar
C240
So what would be best fitting for our c-classes? I'm planning on changing my sparkplugs to NGK iridium..
Old Mar 21, 2011 | 07:22 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
^ NGK Iridium are OEM for the 4-cylinder M271. Not sure what the OE spark plugs are for your V6 but I'm sure NGK Iridiums will work just fine.
Old Mar 21, 2011 | 08:19 AM
Silver C's Avatar
C240
Thanks man, i keep forgetting that inhave a v6 engine under my hood..
