Help.. I can't lower my 4-matic
Old Dec 2, 2005 | 02:00 PM
catwalk's Avatar
C 240 4-matic wagon
My car is in the shop, and I just found out no one makes springs or coilovers for my c240 4-matic . Can anyone here help.please ? I called H&R, renntech, and eibach(tireracks web site is wrong, i bought those already) Thanks
Old Dec 2, 2005 | 07:05 PM
Bing's Avatar
C320 Sport Sedan 4MATIC, Cayenne S, Bayliner Capri V8, Subaru STi
huh?
Old Dec 2, 2005 | 10:00 PM
catwalk's Avatar
C 240 4-matic wagon
huh?
I can't find springs for my 4-matic....!!!
Old Dec 2, 2005 | 10:25 PM
Bing's Avatar
i would leave the springs alone, it's got a unique suspension
it's a 4MATIC
error messages will pop up in the instrument cluster
Originally Posted by reindhar7
I don't think you could lower your car if you have 4MATIC. I have asked a few places to get my C240 4MATIC lowered, but they said 4MATICs have different suspensions from the 2WD C-class and they didn't have the suspension to get the car lowered. If you have airmatic in your E-class, I believe you could lower it using star diagnose (although not much).
From Here
Old Dec 2, 2005 | 10:28 PM
Buellwinkle's Avatar
Most people lift 4x4's. Do they have a lift kit for it? Then you can put some 35" swamp tires and be the talk of the town. You can always do it the old fashioned way, cut the springs.
Old Dec 2, 2005 | 10:29 PM
I KOMPRZ's Avatar
2004 C230k (SOLD), 2005 C230k (Lease ended), 2004 Carrera 4 Cab, 2007 530i
correct me if I am wrong, a 4-matic is a 4 wheel drive, how is the suspension any different from the std 2WD? They should be the same no? I am just guessing those manufacturers do not have their parts listed for 4matics becoz they are not as common. They should be the same as long as they are for W203...ok someone confirm this for the poor guy.
Old Dec 2, 2005 | 11:11 PM
catwalk's Avatar
C 240 4-matic wagon
springs
on a 2 wheel drive the front springs have the same outside diameter from top 2 bottom, 4-matic spings are shaped more like a football lets say 3" on the top and bottom and 5" in the middle.
Old Dec 2, 2005 | 11:21 PM
respdoc's Avatar
CLS
Yes, and four wheel burn-outs is usually not one of the reasons people buy 4-matic cars (esp. C240's)..
Point being is why get a car specifically designed for use in all-weather situations and basically defeat one of it's main features by making the car lower thus making the car less capable in snow ?
Old Dec 2, 2005 | 11:26 PM
catwalk's Avatar
C 240 4-matic wagon
I'm not driving the car in a foot of snow! just looking for some info on springs but thanks for the extra comments.
Point being is why get a car specifically designed for use in all-weather situations and basically defeat one of it's main features by making the car lower thus making the car less capable in snow ? [/QUOTE]
Old Dec 2, 2005 | 11:36 PM
r3v1ls's Avatar
C 230K Coupé
You probably won't find any springs for the car. I'm betting that very few people with 4matic would actually want to lower their car. Thus no companies would produce 4matic springs because there is no demand for them. You might be able to lower it a bit through the mb computer...
Old Dec 2, 2005 | 11:40 PM
respdoc's Avatar
CLS
Well it looks like you already checked out the obvious so the next set would have to be a custom job.
I also just noticed in your description that it is not only a C240 4-matic it's a C240 4-matic wagon ...my condolences...
Old Dec 2, 2005 | 11:44 PM
respdoc's Avatar
CLS
no...doesn't the computer only come into play for lowering in Airmatic-type suspension's that I believe are not available on the C-class model line ??
His only opinion, and I'm not even sure if the 4-matic's have them, is to change out spring pads to the thinnest diameter. Won't be much of a drop though..
Old Dec 3, 2005 | 01:57 AM
yukpo's Avatar
2002 C320
Well.. I am not sure if same thing applies to W203 4 Matic, but one of my friends got his W210 4 Matic lowered with Brabus springs and had no error sign or anything.. You might want to check with Brabus.. Good luck!
Old Jun 2, 2006 | 08:58 PM
dnasty8305's Avatar
2003 c240
i have a 2003 4matic i put lowering springs on the back and ont the front i just cut one coil and heated the springs rides great just wish they made a whole kit
Old Jun 3, 2006 | 12:51 AM
advans's Avatar
C55 ///AMG, 535xi
TIRERACK....
As I remembereed on the tirerack website, they said "EXCLUDES 4MATIC MODELS"
if I were you, LEAVE YOUR 4matic alone, get ur 19s and leave it
Old Jun 4, 2006 | 02:28 PM
white_w203's Avatar
is SOLD
that's sucks about 4-matic models.
